Power_user_EX
Newbie level 3
Hi all,
The below doubts are w.r.t DC source/circuits.
#1)I m really confused with the relation of I and V in power supplies and DC DC convertors.
For e.g. given a 5v battery @ 1000mah.
Now if i want to convert 5V to say 50V or 100V then what will be the max current that the any load can take across the output.
#2) I mean is voltage increased at the cost of amperage/current in charge pumps , voltage booster ??? =or= is current and voltage inter-conversion possible ???
#3) also, i want to know more about constant current circuit - plz guide.
#4) Assume that i have a 6V NiMh battery source @ 2500 mah and i have 6V 'DC' supply form an eliminator or SMPS which has 220V AC power source. Whats the difference between the 2 power sources w.r.t current ?????( I believe 6V from eliminator has constant current.)
#5) What is the effect on load like a DC motor if it is subjected to constant current source opposed to a battery source.(consider the dc motor is having full 'load' so that it eats up max amps)
-thx,
Power_user_EX
-thx,
Power_user_EX
