VLSI physical design (cadence library)
Crazyshan
Newbie level 1
Newbie level 1
i got a warning message at synthesis stage saying "Library cell has no output pins defined. [LBR-9]
: Library cell 'BOUNDARY_LEFTBWP40P140' must have an output pin." and some other cells with same warning. these cells are physical cells defined in library.can i ignore this warning or do i need to fix it? if yes how to fix it what is the command? i'm using cadence genus for synthesis
safe to ignore
