visual c++ SDK or MFC
VC++ got so much popularity due to the MFC.Its so far the hugest library for Windows.Its pretty tough too.But it covers every aspect of windows programming ...
Kareja
Hi, I'm using VC++ with MFC. It's much easyer to program with MFC...
I want to learn programming in MSVC++, so should I start from MFC.
Besides, is there a good VC++ reference on the net, besides MSDN site.
Magnetra
Magnetra
Check this www.codeproject.com
Vedas
check codeguru.com also. your reference point should be the forum in it
SDK contains APIs for windows programming, mostly its like C proramming i.e its close to procedural
MFC is Microsoft Foundation classes. Microsoft provided various classes and their methods which are actually wrapper around SDK. So in MFC mostly u work in Object oriented environment.
for programming, MFC is more flexible, less amount code is required to be written by programmer as all the complexity is handled by classes defined.
SDK requires lot of code to be written by programmer but obviously optimised code can be wriiten in SDK
