[PIC] Visitors Counter with PIC16F877A (2 photoresistors)
Larbi Rahmani
I'm working on a visitors counter on 7 segments display, and when the number reaches 0 a relay is switched off.
but I'm running with some problems with simulation with proteus ISIS, and I couldn't know where the problem is:
Simulation: (I'm using 2 photoresistors)
code:
#define   Relay      RB7_bit
long  POT,POT2;
unsigned char ar[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
unsigned int compt = 0;
void interrupt()
 while(INTF)
    while(POT>=125)
        point1:
        if(POT2>=125)// check the direction from 1 to 2
         if(compt<9)compt++;
         else compt = 9;
         Delay_ms(500);
         break;
        else
         goto point1;
    while(POT2>=125)
       point2:
       if(POT>=125)// check the dirrection from 2 to 1
         if(compt>0)compt--;
         else compt = 0;
         Delay_ms(500);
         break;
        else
         goto point2;
   INTF_bit = 0;// clear flag
   break;
void main(){
TRISA0_bit = 1;//set as input
TRISA1_bit = 1;// set as input
TRISB7_bit = 0;// set as output
TRISB=0x00;
ADCON0 = 0x05;
  // interrupt settings...
  GIE_bit = 1;// Enable global interrupt
  INTE_bit = 1;// Enable external interrupt
  INTEDG_bit = 0;// interrupt on falling edge
  INTF_bit = 0;
   PORTB=ar[compt];
  while(1)
    delay_ms(500);
  POT = ADC_Read(0);
  POT = POT*255/1023;
  POT2= ADC_Read(1);
  POT2= POT2*255/1023;
            if(compt>0)
            Relay = 1;
            else
            Relay = 0;
   PORTB=ar[compt];
Can you help please, because number isn't incrementing.
What causes an interrupt? The photocell input?
I'm not familiar with proteus, but I would verify that the interrupt routine actually gets called.
When someone crosses the first photoresistor then the second the counter increases. and vise versa.
Frpm your design i can see that your Relay is incomplete, supply the relay! or will you use Red and blue code to determine your results?
yes I'm just testing, but the counter didn't start no metter what configuration I make, I can't see where the problem is.
as i saw in interrupt u have keep pointer in while loop twise. so this should not ne done in interrupt routine??
and what exactly problem u r facing?????
I based my simulation on this blog post:
he is using it with no problems
hello,
INTF is RB0 interrupt... with RB0 as input , but connected to 7segment display ???
Never use "While" loop and "goto" inside an interrupt.. very bad habit.
Impossible to follow your mind !
