virtuoso display twinklling via Exceed connection
icnewer
Junior Member level 3
icfb 1920x1200
:?: Hi Gugs,
I use C@dence's virtuoso GUI mode, but there are always twinklling problems when I use PC as terminal and connected to Solaris Workstation using Exceed. But there is no problems if I use Linux logged in the PC and rlogin from linux PC to Saloris. IS it video display card limitation problem or Ethernet speed problem? BUt I use 100M LNA, should be enough for Solaris to PC data transform.
Each time when I open a GUI view of cell (either abstract or layout view), the GUI window twinkling, so terrible it is for eyes! So anyone who has the same experience to solve it? :evil:
manual exceed connection
I don't know the real reason, but I set 256 color mode (no True or High color) for my display setting when I work with Exceed.
exceed pseudocolor
oh, really?! you say we can't use the advance video development when using Virtouso? Not so good, nayway work is first!
cadence xdpyinfo
it's c@dence problem.
which version of exceed do you use? high than 7.0 better.
for i know, if you use true color mode, you can use virtouso but there are some display problem on it. you must refresh again & again.
if you try 256 color mode, the windows display......
icfb performance in citrix
I've had same problem.
I'm working on Windows 2000 (HiColor mode) and connect to LINUX (TrueColor mode) box thru Exceed, which is set to PseudoColor mode. If I run icfb in 24-bit mode on Windows, the display refresh/twinklling every now and then. However, when I switch icfb to 8-bit (default) mode, the problem is gone.
hummingbird exceed /dev/fbs
My experience
is also bad for other than 8-bit color-W2k and 8-bit icfb. I tried:
Exceed 6.0 (little old)
X-Win (only try version)
X-Manager (only try version)
Citrix (used mostly if disconnect is required)
Exceed (newest try version)
X-Win is good
also the newest Exceed but only if IC5032 is used
Because I have to mix IC446 and IC5032 I came back to 8-bit-color mode. I think the problem is because of "online selection" feature of cds. So a mouse move change the grafic drawings. It is the only grafic stuff which differentiate the trouble.
Actually, I use Exc11d 8.0. It's still twinklling, which is so bad and I think no one can tolerate it!!! I tried setting display (Pls, I use MS2000 in PC) to 256-color, it true OK, but the GUI seems so ugly.
rfsystem said:
My experience
X-Win is good
Sorry, maybe a silly question: can i know my icfb is 8-bit or 16-bit or 64-bit mode? which command? I think the default should be 32-bit in workstation, right?
use xdpyinfo to check VISUAL mode
It is a known problem of Cadence IC.
You can find the answer in Sourcelink.
Sorry, can u explain some little more? Now I can't access to SourceLink.
I checked xdpyinfo:
atherton_[/user/home/bryanw]%xdpyinfo
name of display: 10.1.1.94:0.0
version number: 11.0
vendor string: Hummingbird Ltd.
vendor release number: 8000
maximum request size: 4194300 bytes
motion buffer size: 1
bitmap unit, bit order, padding: 8, MSBFirst, 32
image byte order: MSBFirst
number of supported pixmap formats: 4
depth 1, bits_per_pixel 1, scanline_pad 32
depth 8, bits_per_pixel 8, scanline_pad 32
depth 12, bits_per_pixel 12, scanline_pad 32
depth 24, bits_per_pixel 32, scanline_pad 32
keycode range: minimum 8, maximum 254
focus: window 0x3800009, revert to PointerRoot
number of extensions: 13
BIG-REQUESTS
DOUBLE-BUFFER
Extended-Visual-Information
HCL-DOS-Access
HCLMISC
HCLxperf
LBX
SECURITY
SHAPE
TOG-CUP
XC-APPGROUP
XC-MISC
XInputExtension
default screen number: 0
number of screens: 1
screen #0:
dimensions: 1024x768 pixels (310x230 millimeters)
resolution: 84x85 dots per inch
depths (4): 1, 8, 12, 24
root window id: 0x34
depth of root window: 24 planes
number of colormaps: minimum 8183, maximum 8183
default colormap: 0x20
default number of colormap cells: 256
preallocated pixels: black 0, white 16777215
options: backing-store WHEN MAPPED, save-unders NO
largest cursor: 32x32
current input event mask: 0x78003f
KeyPressMask KeyReleaseMask ButtonPressMask
ButtonReleaseMask EnterWindowMask LeaveWindowMask
SubstructureNotifyMask SubstructureRedirectMask FocusChangeMask
PropertyChangeMask
number of visuals: 3
default visual id: 0x23
visual:
visual id: 0x21
class: PseudoColor
depth: 8 planes
available colormap entries: 256
red, green, blue masks: 0x0, 0x0, 0x0
significant bits in color specification: 8 bits
visual:
visual id: 0x22
class: PseudoColor
depth: 12 planes
available colormap entries: 4096
visual:
visual id: 0x23
class: TrueColor
depth: 24 planes
available colormap entries: 256 per subfield
red, green, blue masks: 0xff, 0xff00, 0xff0000
So how should do then?
The Startscript will set the X-Server-ColorDepth on 8 Bit and restart the X-Server.
Now you can login as normal. The Login process will choose your default Session (normal CDE).
ColorDepth Setting on SunBlade
First you login in a CDE or KDE Session then type the next command:
corona.saj[1] ~ > m64config -prconf
--- Hardware Configuration for /dev/fbs/m640 ---
ASIC: version 0x27004752
DAC: version 0x0
PROM: version 106
Card possible resolutions: 720x400x85, 640x480x60, 640x480x72, 640x480x75
800x600x56, 800x600x60, 800x600x72, 800x600x75, 1024x768x60
1024x768x70, 1024x768x75, 1280x1024x75, 1024x768x85, 800x600x85
640x480x85, 1280x1024x60, 1152x900x66, 1152x900x76, 1280x1024x67
1600x1280x76, 1920x1080x72, 1280x800x76, 1440x900x76
1600x1000x66, 1600x1000x76, 1920x1200x70, 1280x1024x85
1280x1024x76, 1152x864x75, 1600x1200x75, 1600x1200x60
1024x768x85, 800x600x75, 640x480x85, 1920x1200x60, 1920x1080x60
vga, svga, 1152, 1280, 800x600, 1024x768, 1280x1024, 1152x900
1600x1280, 1920x1080, 1600x1000, 1920x1200, 1600x1200
Monitor possible resolutions: 720x400x70, 640x480x60, 640x480x67
640x480x72, 640x480x75, 800x600x56, 800x600x60, 800x600x72
800x600x75, 832x624x75, 1024x768x60, 1024x768x70, 1024x768x75
1280x1024x75, 1280x1024x60, 1152x900x66, 1280x1024x76, 800x600x75
vga, svga, 1280, 800x600, 1024x768, 1280x1024
Possible depths: 8, 24
Current resolution setting: 1280x1024x60
Current depth: 24
corona.saj[2] ~ > m64config -depth 8
To set a new resolution:
corona.saj[3] ~ > m64config -res 1280x1024x60
Restart the X-server by a logout-login.
One problem now occur:
You know I use PC as displaying terminal and connected to SunBlade via Exceed, so I have no access right to do "m64config" on SunBlade WorkStation. Actually I tried the steps what you indicated, but definitely it response: Permission denied. If so, only administrator can do this, right? but change this config will also affect other programme's displaying effect, so changing should be not accepted by administrator. Can only lowen my PC displaying depth to 8 to solve this problem? Hope further response!
you can try:
Exceed->Xconfig->Performance->deselect "Draft Mode" ->click "Tune..."->click "OK" if prompted->save all changes and quit
Great, you are right. Hope keep this topic on TOP for some time, that others can also know this solution. :D :D :D :D
