Torie
- Joined
- Jun 18, 2012
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Fort Collins, CO
- Activity points
- 1,328
Hi!
I am new to working with the master/slave boundaries and arrays in HFSS and I was wondering if there is a way to preview the array that will be simulated. I am trying to do an offset array by using the tips I found in the HFSS help section, but I want to verify it is building the array as I intended.
The image I attached is from the HFSS help section. I want to preview it as they have done in this help topic but I don't know if they just put that image together for instructional purposed or if you can actually preview the array.
Any suggestions?
Thanks!!!
T
Figured it out - right click Model and select create array. It only creates a finite array but I got the information I needed.
Any suggestions?
Thanks!!!
T
