Via dimensions are way off course, why?
skatefast08
Full Member level 4
Full Member level 4
Hey guys, I am using Eagle PCB software. As shown below, I pick a via from the pallet to the left, then I place it onto the board and I notice that the via has a larger diameter than I intended. As you can see also I enter the diameter of the via as 0.381 mm as shown in properties, then I use the dimension ruler to check the diameter of the via on the board and it shows 0.72 mm. What is going on?
You did not mention what CAD is it, anyway in general the ruler is not a good method to take primitive dimensions once it depends on your ability to align correctly, moreover you did not zoomed the via which would lead to a higher measuring error; the properties panel is the most suited way to do that, as you did.
Look at your design rules for "via restring" setup.
Klaus
Eagle is a way off the layout tool standard in its way to setup via parameters, but it's all explained in the manual. The actual diameter is shown as "outer layer diameter" in the dialog. You are inaccurately measuring 0.66 as 0.72 mm.
Hello skatefast08,
Are you sure that the visible diameter is of copper layer and NOT the soldermask ?
Regards,
Maqbool
Manufacturers tend to use metric drills in 0.1mm increments, use a sensible metric dimension for your hole sizes, this is the 21st Century after all. Use 0.3 or 0.4mm for finished via size.
