hitx
Member level 2
Hi dear friends,
I have a problem about my codes, but I am not sure whether the problem is about while loop or not. Therefore I need someone help. My code in VHDL is as below :
if rising_edge(q) then
while i <= 3 loop
Xn := 4.0 * Xn * (1.0 - Xn) ;
y := floor (100.0 * Xn);
m <= integer ;
n := m mod 256;
result <= std_logic_vector (to_unsigned(n,8));
i := i + 1;
end loop;
end if;
In here, "q" is a clock signal having 0.75 Hz frequency. And I want to display "result" in 8 bits through leds (0-7) in FPGA board. So loop will iterate 3 times, each iteration I should observe 64,92 and 29 respectively. Now, the clock frequency is 0.75 Hz, I need to observe the numbers. However, I observed only the final value as 29 without observing 64 and 92. So in which part of the codes I missed?
Please help. Thanks.
while i <= 3 loop
m <= integer ;
n := m mod 256;
i := i + 1;
end loop;
end if;
