angjohn
Junior Member level 2
do u any1 of u know how to translate foolwing VHDL code to Verilog other than the verilog source code i show below ( can any1 know how to translate the code to verilog without using the disable Stament)!
VHDL :
Verilog
VHDL :
-- BitComparator
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity BitComparator is
port (
d : in STD_LOGIC_VECTOR(15 downto 0);
whichbit : in STD_LOGIC_VECTOR(3 downto 0);
set : out STD_LOGIC;
en : in STD_LOGIC;
CLK : in STD_LOGIC
end BitComparator;
architecture BitComparator_arch of BitComparator is
signal BitSelect : STD_LOGIC;
begin
-- Enter concurrent statements here
process(clk, en)
begin
if(clk'event and clk='1') then
--BitSelect <= '0';
if (en = '1') then
for i in 0 to 15 loop
BitSelect <= d(i);
exit when (i = whichbit);
end loop;
end if;
end if;
end Process;
Set <= BitSelect;
end BitComparator_arch;
Verilog
// BitComparator
module BitComparator (d, whichbit, set, en, CLK);
input[15:0] d;
input[3:0] whichbit;
output set;
wire set;
input en;
input CLK;
reg BitSelect;
always @(posedge CLK)
begin
if (en == 1'b1)
begin
begin : compare
integer i;
for(i = 0; i <= 15; i = i + 1)
begin
BitSelect <= d[i] ;
if ((i == whichbit)) disable compare;
end
end
end
end
assign set = BitSelect ;
endmodule
