Y.SAI SARASWATHI
Member level 4
Hello,
I am using xilinx ISE 10.1, following is the code snippet.
It is not showing any errors but it is taking read,cs_adc as logic '1' always. It is displaying following warnings
Thank you.
u3rocess(samp_clk,eoc_adc)
Begin
if(samp_clk'event and samp_clk='1')then
conv_start<='0';
conv_start<='1'after 20ns;
if(eoc_adc'event and eoc_adc='1') then
cs_adc<='0';
rd<='0';
rd<='1' after 15ns;
cs_adc<='1' after 15ns;
end if;
end if;
end Process u3;
rd_adc<='0'when rd='0'else '1';
My design is when adc gives active low eoc ,after that when it returns again to logic'1' then we should send read signal for 10ns.That is why I have written in that way,Is there any other correct way.-Register <conv_start> in unit <DPCM> has a constant value of 0 during circuit operation. The register is replaced by logic.
- Register <cs_adc> in unit <DPCM> has a constant value of 0 during circuit operation. The register is replaced by logic.
- Register <rd> in unit <DPCM> has a constant value of 0 during circuit operation. The register is replaced by logic.
WARNING:Xst:647 - Input <eoc_adc> is never used.
Thank you.
