VHDL Syntax error in Modelsim simulator
venkatec
Newbie level 6
Newbie level 6
Hyderabad
Hi Frnds,
Below vhdl statment is giving syntax error in modelsim simulator,Could you correct this error.
f0 <= ((seq_pat(0) xnor Rx_data(55))+(seq_pat(1) xnor Rx_data(54))+ (seq_pat(2) xnor Rx_data(53))+(seq_pat(3) xnor Rx_data(52)));
error:** Error: D/binary_pattern_correlator.vhd(74): No feasible entries for infix operator "+".
Thanks,
vk
error vhdl infix operator
I beleave your problem is the + operator does not understand one or two of the types coming into it and/or out of it.
Try converting all the + operator inputs to integers and back again like so:
f0 <= conv_std_logic_vector(conv_integer(seq_pat(0) xnor Rx_data(55))+conv_integer(seq_pat(1) xnor Rx_data(54))+ conv_integer(seq_pat(2) xnor Rx_data(53))+conv_integer(seq_pat(3) xnor Rx_data(52)),f0'length);
Note: I have assuemed that f0 is a std_logic_vector and you are using these libaries.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
If you will need to use different conversion functions.
Hope this helps.
PS: what are you actualy trying to do here?
Reactions: afarouk
    venkatec
    afarouk
syntax error in vhdl
Thanks for your kind response.
I am trying to find correlation of two sequences ,for that i am using one IEEE
derived fromula..
Yeah "fo" is std logic vector,So i am using the libraries you mentioned.
I will try with your solution and get back to you...
Thanks,
venkat k
Re: VHDL Syntax error
You must mention the ARITH libraries for + to wrk out in your code.
    venkatec
Hi Frnd,
The problem is sloved.
Thanks.
vk
VHDL Syntax error
Hi frnd,
Here is one small issue while simulating below code
signal parallel_data:std_logic_vector(55 downto 0):= "00000000000000000000000000000000000000000000000000000000";
process( clock,reset)
variable count: integer range 0 to 56 := 0;
begin
if clock'event and clock = '1' then
if reset = '0' then
count := 0;
parallel_data <= "00000000000000000000000000000000000000000000000000000000";
parallel_data_out <= "00000000000000000000000000000000000000000000000000000000";
Device_en <= '0';
else
if(count <= 55) then
parallel_data(count-1) <= serial_data_in;
count := count +1
In the above code simulator is strucked at this line
serial_data_in is single bit signal
and giving error like below
# Fatal error in Process line__17 at D:/Vlsiprojects/Student_projects/Sunitha_pj/Code_development/frame_synchronizer/Vhdl_Ver/serial_2_parallel.vhd line 28
28 th line is
Please give me correct syntax for this..
Thanks,
vk
else
count := count +1
are any other set of conditions you rae checking in the else conditions ?
please check the syntax
elsif
instead of else
if (...... .... . .. )
please do let me know the rest of the code.
Try this:
if count = 55 then --I only changed this line
count := count +1;
end if;
I Sloved this problem.
in this code bug is here..
Here count is range from 0 to 55
so i am doing count-1 operation that means 0 -1 = -1
-1 is not in the range of count.SO that is why simulator is strucked at this point..
Thanks,
vk
Added after 1 hours 19 minutes:
