ash72
Newbie level 5
Folks,
I am perplexed with VHDL behavior in the following example. It's an EDA playground link, so you can simulate it yourself.
https://www.edaplayground.com/x/Qx_J
My question is why doesn't the process enter when signal 'B' changes in its sensitivity list? The simulation only shows the time 0 uninitialized values of signals in it's sensitivity list. Tried both on Questa and VCS and the same answer.
Thanks for any clarification you can provide.
library IEEE;
use IEEE.Std_logic_1164.all;
use std.textio.all;
entity E1_TB is
end entity E1_TB;
architecture BENCH of E1_TB is
signal A : Std_logic;
signal B : Std_logic;
signal C : Std_logic;
begin
process (A, B, C)
variable var2 : line;
begin
write(var2, string'("ENTER: At Time = "));
write(var2, now);
write(var2, string'(" INPUT = "));
write(var2, A);
write(var2, B);
write(var2, C);
writeline(output, var2);
C <= B after 4 NS;
B <= A after 10 ns;
write(var2, string'("EXIT: At Time = "));
write(var2, now);
write(var2, string'(" iOUT1 = "));
write(var2, A);
write(var2, B);
write(var2, C);
writeline(output,var2);
end process;
Stim: process
begin
wait for 1 ns;
B <= '0';
wait for 25 NS;
B <= '1';
wait;
end process;
end architecture;
