Soh_bhat
Junior Member level 1
Hi there,
I have tried to add and subtract to check the for loop using two equations. But, whenever I am using it, it is giving result of first step only and the loop is unrolling. What is the error in my code?
It is giving the first output only.
PLease help!!!
Behavioural:
package pk5 is
type T is range 0.0 to 50.0;
type T1 is array (0 to 3) of T;
end pk5;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use work.pk5.all;
entity add is
Port ( x : in T1 ;
y : in T1;
h : in T;
x_o : out T1;
y_o : out T1);
end add;
architecture Behavioral of add is
signal p, q : T1;
begin
process(x, y, h)
begin
x_o(0) <= 0.0;
y_o(0) <= 0.0;
addi: for i in 1 to 3 loop
x_o(i) <= x(i-1) + h;
y_o(i) <= y(i-1) - x(i-1);
end loop;
end Behavioural;
Test Bench:
library IEEE;
use work.pk5.all;
entity add_TB is
end add_TB;
architecture Behavioral of add_TB is
component add is
Port ( x : in T1;
y : in T1;
h : in T;
x_o : out T1;
y_o : out T1);
end component;
signal x: T1;
signal y: T1;
signal h: T;
signal x_o: T1;
signal y_o: T1;
begin
uut: add port map (
x => x,
y => y,
h => h,
x_o => x_o,
y_o => y_o);
add_proc: process
begin
x(0) <= 1.0;
y(0) <= 10.0;
h <= 0.1;
wait for 5 ns;
end process;
end Behavioral;
PLease help!!!
