nandu said:Hi all
I would like to know the instruction used to read data from a file, and also to write into a file.
thank you
file inFile : text open read_mode is "input.txt"; -- input file
file outFile : text open write_mode is "output.txt"; -- output file
variable ln : line; -- string in file
variable ch : character; -- character in the line
readline(inFile,ln); -- read string line from the file inFile and store it to "ln"
read(ln,ch,res); -- read next character "ch" from string line "ln"
write(ln,ch); -- write character "ch" to line "ln"
writeline(outFile,ln); -- write string to output file
library ieee,std;
use ieee.std_logic_1164.all;
use ieee.std_logic_textio.all;
use std.textio.all;
entity tb is
end tb;
architecture beh_tb of tb is
component dff
port ( d : in bit;
q : out bit;
clk : in bit;
rst : in bit
end component;
signal d_s,q_s,clk_s,rst_s : bit;
signal cntr : bit ;
begin
U1 : dff port map ( d => d_s , q => q_s , clk => clk_s , rst => rst_s);
clk_gen : process
begin
clk_s <= '0' ;
wait for 5 ns;
clk_s <= '1';
wait for 5 ns;
end process;
reset_gen : process
begin
rst_s <= '0' ;
wait for 5 ns;
rst_s <= '1' ;
wait for 200 ns;
end process;
file_proc : process
file ipfile : text is in "/home/js17421/vhdl/text/ipf.txt";
file opfile : text is out "/home/js17421/vhdl/text/abc";
variable ip_line : line;
variable op_line : line;
variable d_v :bit;
variable i,j : integer;
begin
while not(endfile(ipfile)) loop
readline(ipfile,ip_line);
read(ip_line,d_v);
d_s <= d_v;
i := i + 1;
wait for 10 ns;
assert not(endfile(ipfile))
report " FILE FINISHED "
severity note;
end loop;
wait for 100 ns;
while (j < i) loop
if (j = 1 ) then
write(op_line,string'("OUTPUT ") );
writeline(opfile,op_line);
end if;
write(op_line,q_s);
j := j + 1;
wait for 10 ns;
end loop;
end process;
end beh_tb;
