VHDL enumerated type _ basic question
graphene
Full Member level 2
Full Member level 2
Germany
This is a very basic question in VHDL. I am askign this after unable to find a clear answer in various internet pages.
In VHDL, we use the ENUMERATION type. Normally a type is defined even for a signal, however, here for enumerated type it just goes like
HTML:
type COLOR is (BLUE, GREEN, YELLOW, RED);
variable HUE: COLOR;
type my_type is (ST1, ST2, ST3, ST4, ST5, ST6, ST7, ST8);
signal pres, nex: my_type;
so the object type like std_logic, or bit or similar thing is not specified to this enemurated type COLOR. Can I use one of its component lets say Blue for a bit, green for a signed bit vector, etc?
Can somone explain the logic behing this?
Thanks in advance.
std_logic is defined in the following manner:
type std_ulogic is ('U', 'X', '0', '1', 'Z', 'W', 'L', 'H', '-') ;
subtype std_logic is resolved std_ulogic ;
Hence, std_logic is a subtype of the enumerated type std_ulogic.
VHDL is a strongly typed language. You may only use two types together if they are the same or one is a subtype of the other (like std_logic and std_ulogic). Hence, you may not assign a value of COLOR to nex and you may not assign a value of std_logic to nex.
What you are really struggling with is, "How does the synthesis tool assign bit values to my state vector?" This is a process that is independent of the language. To get something particular you will have to learn about the statemachine attributes your synthesis supports - unfortunately the synthesis vendors have ignored IEEE attempts to standardize this.
If you are employed by a profitable company, you might want to consider taking a VHDL class (such as one from SynthWorks - my company) or if not, invest in a good book.
Jim
In many cases, an enumeration type is similar to an integer range, e.g. the states of a finite state machine. As explained, it's not possible to use it in a different, incompatible enumeration. And it would neither make sense, I think.
thank you Synthworks.
I got your points.
Let me think this as an language independant attribute though no textbook makes sense with this regard.
thankyou FvM... I actually do not want to mix the signals aber just to know as in what is happening. thanks for your time...
