VHDL92
Newbie level 3
Hi guys i'm new to this so bear with me.
I've been assigned to program a VHDL code for a 4bit down counter using half/full subtractors. I've got the sample testbench from my supervisor as shown below.
Counter testbench:
library ieee;
use ieee.std_logic_1164.all;
entity mycounter_testbench4 is
end mycounter_testbench4;
architecture mycounter_tb4 of mycounter_testbench4 is
signal count: std_logic_vector(3 downto 0);
signal clk: std_logic:='0';
signal reset: std_logic;
component counter4
port(countut std_logic_vector(3 downto 0);
clk:in std_logic;
reset:in std_logic);
end component;
begin
counter_circuit : counter4
port map(count => count, clk => clk, reset => reset);
clockrocess
begin
wait for 10ns;
clk <= not clk;
end process clock;
test_resetrocess
begin
wait for 5ns; reset <= '1';
wait for 4ns; reset <= '0';
wait;
end process test_reset;
end mycounter_tb4;
Now i'll need to program a code for this and i have some problems. Below are my codes.
library ieee;
use ieee.std_logic_unsigned.all;
entity counter4 is
clk:in std_logic;
end counter4;
architecture behav_counter4 of counter4 is
component ha port (a: in std_logic;
b: in std_logic;
sum: out std_logic;
c_out: out std_logic);
end component;
component fa port (a, b, cin : in std_logic;
sum, c_out : out std_logic);
end component;
signal ain,s,c:std_logic_vector(3 downto 0) :="0000";
signal bin:std_logic_vector(3 downto 0):="0001";
begin
u1:ha port map(a => ain(0), b => bin(0), sum => s(0), c_out => c(0));
u2:fa port map(a => ain(1), b => bin(1), sum => s(1), cin => c(0), c_out => c(1));
u3:fa port map(a => ain(2), b => bin(2), sum => s(2), cin => c(1), c_out => c(2));
u4:fa port map(a => ain(3), b => bin(3), sum => s(3), cin => c(2), c_out => c(3));
counterrocess(clk, reset) --process(sensitivity list)
begin
if reset'event and (reset = '1') then
s <= (others => '0');
elsif clk'event and (clk='1') then
ain <= c xor ain;
s <= ain xor bin;
c <= s and c;
end if;
end process;
count <= s;
end behav_counter4;
Really hope you guys can help me with this. I've got 8 weeks left to submission.
Counter testbench:
library ieee;
component counter4
clk:in std_logic;
end component;
begin
clockrocess
begin
wait for 10ns;
clk <= not clk;
end process clock;
test_resetrocess
begin
wait;
end mycounter_tb4;
library ieee;
entity counter4 is
clk:in std_logic;
end counter4;
b: in std_logic;
sum: out std_logic;
end component;
end component;
begin
begin
ain <= c xor ain;
s <= ain xor bin;
c <= s and c;
end if;
end process;
count <= s;
end behav_counter4;
