hawluchapikaa
Newbie
![Newbie level 1](/styles/images/ranks/alevel1.gif)
A VHDL design code for a remote-controlled garage door opener with sensors is provided to us. It has 8 states, 4 for each door. Testbench is not provided, and I did one (with help of testbench generator as well). The output should look something like this:
I used web application called EDA Playground for simulation. Below is the link of it:
Kinda new to this. Don't know why it doesn't run.
Is there supposed to be a proper sequence of inputs for this specific code or am I missing some other inputs, such as those in testbench stimuli?
Hope someone could help analyzing the design and what I should put in the testbench stimuli cause
I think I'm missing something.
[MODERATOR ACTION]
Embedded code to the thread
Design
Testbench
[MODERATOR ACTION]
Design
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity garage_door_controller is
port (
remt, sen1, sen2, clk, rst : in std_logic;
ctr : out std_logic_vector (1 downto 0)
end entity;
architecture moore_fsm of garage_door_controller is
type state is (closed1, closed2, opening1, opening2, open1, open2, closing1, closing2);
signal pr_state, nx_state : state;
begin
process (clk, rst)
begin
if rst = '1' then
pr_state <= closed1;
elsif rising_edge(clk) then
pr_state <= nx_state;
end if;
end process;
process (pr_state, remt, sen1, sen2)
begin
case pr_state is
when closed1 => ctr <= "00";
if remt = '0' then
nx_state <= closed2;
else
nx_state <= closed1;
end if;
when closed2 => ctr <= "00";
if remt = '1' then
nx_state <= opening1;
else
end if;
when opening1 => ctr <= "10";
if sen1 = '1' then
nx_state <= open1;
elsif remt = '0' then
nx_state <= opening2;
else
end if;
when opening2 => ctr <= "10";
if remt = '1' or sen1 = '1' then
nx_state <= open1;
else
end if;
when open1 => ctr <= "00";
if remt = '0' then
nx_state <= open2;
else
nx_state <= open1;
end if;
when open2 => ctr <= "00";
if remt = '1' then
nx_state <= closing1;
else
nx_state <= open2;
end if;
when closing1 => ctr <= "11";
if sen2 = '1' then
nx_state <= closing2;
else
end if;
when closing2 => ctr <= "11";
if remt = '1' or sen2 = '1' then
else
end if;
end case;
end process;
end architecture;
Testbench
library ieee;
use ieee.std_logic_1164.all;
entity tb_garage_door_controller is
end tb_garage_door_controller;
architecture tb of tb_garage_door_controller is
component garage_door_controller
port (remt : in std_logic;
sen1 : in std_logic;
sen2 : in std_logic;
clk : in std_logic;
rst : in std_logic;
end component;
signal remt : std_logic;
signal sen1 : std_logic;
signal sen2 : std_logic;
signal clk : std_logic;
signal rst : std_logic;
signal ctr : std_logic_vector (1 downto 0);
constant clk_period : time := 10 ns;
begin
dut : garage_door_controller
port map (remt => remt,
sen1 => sen1,
sen2 => sen2,
clk => clk,
rst => rst,
ctr => ctr
clk_process :process
begin
clk <= '0';
wait for clk_period/2;
clk <= '1';
end process;
stimuli : process
begin
remt <= '0';
sen1 <= '0';
sen2 <= '0';
rst <= '1';
wait for clk_period*10;
rst <= '0';
remt <= '0';
remt <= '1';
sen1 <= '1';
sen2 <= '1';
remt <= '1';
remt <= '1';
wait;
end process;
end tb;
configuration cfg_tb_garage_door_controller of tb_garage_door_controller is
for tb
end for;
end cfg_tb_garage_door_controller;
