daniel bet
Newbie
need to implement counter to 100 that increase his count every push button press, it has debouncing circuit using rising edge detector, I got mistakes in the simulation, the counter increases without syncing the push press button. I’m not sure where is the problem, please help me
the clk is 100Mhz
here is the code:
I think I have problem in the test bench, I'm not sure
the clk is 100Mhz
here is the code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.all;
use IEEE.std_logic_unsigned.all;
entity counter is
Port ( clk : in STD_LOGIC;
reset : in STD_LOGIC;
button : in STD_LOGIC;
count : out STD_LOGIC_VECTOR (6 downto 0)
end counter;
architecture Behavioral of counter is
signal debounced_button : std_logic;
signal prev_debounced_button : std_logic := '0';
signal counter_value : unsigned(6 downto 0) := (others => '0');
begin
-- Debounce the button signal using a rising edge detector
process (clk)
begin
if rising_edge(clk) then
if button = '1' and prev_debounced_button = '0' then
debounced_button <= '1';
else
debounced_button <= '0';
end if;
prev_debounced_button <= debounced_button;
end if;
end process;
-- Count up when the button is pressed
process (clk, reset)
begin
if reset = '1' then
counter_value <= (others => '0');
elsif rising_edge(clk) then
if debounced_button = '1' then
if counter_value = 100 then
else
counter_value <= counter_value + 1;
end if;
end if;
end if;
end process;
-- Convert the counter value to a std_logic_vector for output
count <= std_logic_vector(counter_value);
end Behavioral;
——test bench:
library IEEE;
entity counter_tb is
end counter_tb;
architecture Behavioral of counter_tb is
component counter
end component;
signal clk : std_logic := '0';
signal reset : std_logic := '0';
signal button : std_logic := '0';
signal count : std_logic_vector(6 downto 0);
-- Stimulus process to generate clock and input signals
begin
uut: counter port map (
clk => clk,
reset => reset,
button => button,
count => count
clk_gen: process
begin
clk <= '0';
wait for 5 ns;
clk <= '1';
wait for 5 ns;
end process clk_gen;
stim_proc: process
begin
-- hold reset state for 100 ns.
reset <= '1';
wait for 20 ns;
reset <= '0';
wait;
end process;
process
begin
button <= '0';
wait for 40ns;
button <='1';
wait for 40ns;
button <= '0';
wait for 40ns;
button <='1';
wait for 40ns;
button <= '0';
wait for 40ns;
button <='1';
wait for 40ns;
end process;
end Behavioral;
