Vhdl ams syntax error: Hamster
koukou
Newbie level 1
Newbie level 1
Vhdl ams syntaxe error: Hamster
Hello,
The following code results in the error under determined model and the simulation breaks off.
How should I remove the error. I have coded in Hamster Vhdl.
I would appreciate any help.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
entity MEM is
       generic (-- Initial state (between 0 and 1)
       X0 : REAL := 0.1;
       R_OFF : REAL := 16.0E3;
       R_ON : REAL := 100.0;
       D : REAL := 10.0E-9;
       UV : REAL := 1.0E-14);
       port (terminal POS, NEG : ELECTRICAL);
       constant EPS_I : REAL := 1.0E-9;
           begin
       assert (X0 > 0.0) and (X0 < 1.0)
       report "ERROR: X0 in (0,1) required ."
       severity ERROR;
           end entity MEM;
       architecture LINEAR of MEM is
type MODE_TYPE is (FREE , ZERO , ONE);
signal MODE : MODE_TYPE := FREE;
quantity V across I through POS to NEG;
quantity X : REAL;
       begin
        if DOMAIN = QUIESCENT_DOMAIN use
          X == X0;
        elsif MODE = ZERO use
          X == 0.0;
        elsif MODE = ONE use
          X == 1.0;
        else X'DOT == (UV/(D**2))*R_ON*I;
        end use;
        break on MODE;
            V == (R_ON*X + (1.0-X)*R_OFF)*I;
        P1: process is
            begin
            wait on DOMAIN;
            while TRUE loop
                wait on X'above(0.0), X'above(1.0), I'above(EPS_I), I'above(-EPS_I);       ---ERROR--syntax error: Unexpected entry: '
if MODE = FREE then
            if X <= 0.0 then
               MODE <= ZERO;
            elsif X >= 1.0 then
               MODE <= ONE;
            end if;
            elsif MODE = ZERO then
            if I > EPS_I then
               MODE <= FREE;
            end if;
            elsif MODE = ONE then
            if I < -EPS_I then
               MODE <= FREE;
            end if;
            end if;
            end loop;
            end process P1;
        end architecture LINEAR;
