[SOLVED] VHDL addition "1111"+"1111"=FAIL
hardware_guy
Newbie level 6
Newbie level 6
Hi.
I will explain my problem simply.
I'm trying to get summary of 4-bit vectors in one, 8-bit vector.
Code VHDL - [expand]
8
9
10
signal cnt1,cnt2,cnt3,cnt4,cnt5 : STD_LOGIC_VECTOR (3 downto 0);
signal count                  : STD_LOGIC_VECTOR (7 downto 0);
cnt1 <= "0000";
cnt2 <= "0000";
cnt3 <= "0000";
cnt4 <= "0001";
cnt5 <= "1111";
count <= cnt1 + cnt2 + cnt3 + cnt4 + cnt5;
I'm expecting to get "00010000" on "count", but I get "00000000"
When I tried this:
count <= "0000"&cnt1 + "0000"&cnt2 + "0000"&cnt3 + "0000"&cnt4 + "0000"&cnt5;
I got "00011111"
Yes, I have read recomendations, to use differnt library or use "integer", but I still fail to understand.
I add this:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.numeric_std.all;
Is it not enough, or is it too much? How to get "00010000" in this example? How to use "integer" in this example?
In my project, each of the counters cnt1-cnt5 will have own reset signal, but I want to join them in to one vector, to make future processing. :-?
https://www.csee.umbc.edu/portal/help/VHDL/operator.html
"+" has higher precedence than "&". thus you get:
count <= "0000" & (cnt1+"0000") & (cnt2+"0000") & (cnt3+"0000") & (cnt4+"0000") & cnt5;
-- "0000" & "0000" & "0000" & "0000" & "0001" & "1111"
-- one of the std_logic_* packages must allow the assignment to work despite the bit-width difference.
-- you want
count <= ("0000"&cnt1) + ("0000"&cnt2) + ("0000"&cnt3) + ("0000"&cnt4) + ("0000"&cnt5);
why not using unsigned in stead of std_logic_vector for cnt and count?
This would make sense from a standard VHDL point of veiw (assuming the OP got rid of std_logic_arith to ensure there were no clashes). But you would still have exactly the same problem.
Re: VHDL addition &quot;1111&quot;+&quot;1111&quot;=FAIL
yes true for the second piece of code - I was referring to the original part in post #1.
'+' has higher precedence than '&'
Presuming the poster want to learn reasonable VHDL coding style instead of using outdated libraries, I would suggest (with unsigned type for all signals)
count <= resize(cnt1,8) + cnt2 + cnt3 + cnt4 + cnt5;
The other summands are automatically resized to 8-bit unsigned before being added. The advantage of resize() is that it also peforms sign extension for signed signals.
Thank you all. Your replies have helped me to solve my problem.
