VGA HD 15 to Composite (PAL/NTSC) adaptor
bangunprayogi
Newbie level 5
Newbie level 5
Bandung, Indonesia
Dear all,
I want to build the monitoring system with PAL camera but I have a problem:
My monitor is LCD that use VGA connection but my camera use BNC PAL connection, so I need the VGA to composite adaptor...Does somebody have any advices what product that I should use?
Many THanks.....
if you can construct your own circuit Analog Devices "AD722" RGB to NTSC/PAL encoder IC can be useful for you. if you have opportunity to construct it you should try it.
Added after 1 minutes:
