tahir4awan
Full Member level 4
I was doing my project to drive an induction motor with VFD. The problem occured, when I tried to calculate the speed of the motor. I mean, it is a calculation problem and I am not sure what is correct? We have learnt in our institute that VFD always work with synchronous speed and not with the rated speed. Becasue rated speed is different different due to slip. I had an induction motor with rated speed 1390 r/min. Which means 1500 r/min synchronous speed. If VFD shows 50Hz on display at 1500 r/min then it should show 33.66Hz. at 900 r/min. Because 900 r/min+110 r/min=1010 r/min. And (1010 r/min * 50hz)/1500 r/min = 33.66Hz.
But my supervisor told me that I should use this calculation, i.e at 1390 r/min VFD shows 50Hz then at 900 r/min it shows, (900 r/min * 50Hz) / 1490 r/min = 32.37 Hz. Which is a little bit different. Has anyone any idea, what is the correct way of calculating speed?
Thanks
Thanks
