VerilogAMS netlist
pnpr
Newbie
Newbie level 3
I am trying to create a VERILOGAMS netlist of my schematic and I encounter the following errors:
ERROR (OSSHNL-254): Terminal 'VSS1V8A' of place master 'work_praseetha/rxbb_lp/symbol' has no corresponding terminal in
instance 'rxbb_lp_inst' of cellview 'work_praseetha_pseudo/rxbb_lp_pseudo/verilogams'. Either Run hierarchical extraction on the
cellview or set the simSymbolModifiedAction variable to "ignore" and netlist
again.
if I create a netlist of my TB, then I get only the instance of my circuit and not the verilogams netlist.
I need to generate a verilogAMS netlist to drive my analog circuit from a digital TB.
again.
I have the same issue, did you figure this out?
Hey,
For me it was the version of vituoso that prevented me from getting the vamsnetlist. so I had to use another tool to get it, but that is internal and not the right way of doing it.
In short I would say check the virtuoso version if it allows you to do this.
