nyogtha
Newbie level 2
Hello.I got an assignment for my university.I have to make an Adder/Subtractor with the ability to add or subtract 2 numbers with 8 digits named X and Y and to change mode with M.The final Carry must be outputed as G,the Results as R and i added an overflow check called V.I made that code :
And i have the errors :
# ** Error: D:/TEST/Er1v1SetAskLD.v(11): near "[": expecting: IDENT
# ** Error: D:/TEST/Er1v1SetAskLD.v(11): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(12): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(12): near ";": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(13): near "|": expecting: ',' ';'
# ** Error: D:/TEST/Er1v1SetAskLD.v(14): near "[": expecting: IDENT
# ** Error: D:/TEST/Er1v1SetAskLD.v(14): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(15): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(15): near ";": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(16): near "|": expecting: ',' ';'
# ** Error: D:/TEST/Er1v1SetAskLD.v(17): near "[": expecting: IDENT
# ** Error: D:/TEST/Er1v1SetAskLD.v(17): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(18): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(18): near ";": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(19): near "|": expecting: ',' ';'
# ** Error: D:/TEST/Er1v1SetAskLD.v(20): near "[": expecting: IDENT
# ** Error: D:/TEST/Er1v1SetAskLD.v(20): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(21): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(21): near ";": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(22): near "|": expecting: ',' ';'
# ** Error: D:/TEST/Er1v1SetAskLD.v(23): near "[": expecting: IDENT
# ** Error: D:/TEST/Er1v1SetAskLD.v(23): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(24): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(24): near ";": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(25): near "|": expecting: ',' ';'
# ** Error: D:/TEST/Er1v1SetAskLD.v(26): near "[": expecting: IDENT
# ** Error: D:/TEST/Er1v1SetAskLD.v(26): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(27): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(27): near ";": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(28): near "|": expecting: ',' ';'
# ** Error: D:/TEST/Er1v1SetAskLD.v(29): near "[": expecting: IDENT
# ** Error: D:/TEST/Er1v1SetAskLD.v(29): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(30): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(30): near ";": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(31): near "|": expecting: ',' ';'
# ** Error: D:/TEST/Er1v1SetAskLD.v(32): near "[": expecting: IDENT
# ** Error: D:/TEST/Er1v1SetAskLD.v(32): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(33): near "]": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(33): near ";": syntax error
# ** Error: D:/TEST/Er1v1SetAskLD.v(34): near "|": expecting: ',' ';'
# ** Error: D:/TEST/Er1v1SetAskLD.v(35): near "=": expecting: IDENT
# ** Error: D:/TEST/Er1v1SetAskLD.v(35): near "]": syntax error
Can someone Help me solve them?
module BCD_FSA11(X,Y,M,R,G,V);
input [7:0] X,Y;
input M;
output [7:0] R;
output G;
output V;
wire[6:0] C;
wire [7:0] O;
O[0]= M^Y[0];
R[0]= M^X[0]^O[0];
C[0]=(X[0]& O[0]) | (X[0] & M) | (O[0] & M);
O[1]= M ^ Y[1];
R[1]= C[0]^X[1]^O[1];
C[1]=(X[1]&O[1]) | (X[1] & C[0]) | (C[0] & O[1]);
O[2]= M^Y[2];
R[2]= C[1]^X[2]^O[2];
C[2]=(X[2]&O[2]) | (X[2] & C[1]) | (C[1] & O[2]);
O[3]= M^Y[3];
R[3]=C[2]^X[3]^O[3];
C[3]=(X[3]&O[3]) | (X[3] & C[2]) | (C[2] & O[3]);
O[4]=M^Y[4];
R[4]=C[3]^X[4]^O[4];
C[4]=(X[4]&O[4]) | (X[4] & C[3]) | (C[3] & O[4]);
O[5]=M^Y[5];
R[5]=C[4]^X[5]^O[5];
C[5]=(X[5]&O[5]) | (X[5] & C[4]) | (C[4] & O[5]);
O[6]=M^Y[6];
R[6]=C[5]^X[6]^O[6];
C[6]=(X[6]&O[6]) | (X[6] & C[5]) | (C[5] & O[6]);
O[7]=M^Y[7];
R[7]=C[6]^X[7]^O[7];
G=( X[7]&O[7]) | (X[7] & C[6]) | (C[6] & O[7]);
V=C[6]^G;
endmodule
module testbench();
reg [7:0] A,B;
reg C;
wire [7:0] X;
wire Y;
wire Z;
BCD_FSA11 x9(A,B,C,X,Y,Z);
initial begin
A=$random;
B=$random;
C=$random;
#600 A=$random;
B=$random;
C=$random;
#600 A=$random;
B=$random;
C=$random;
end
endmodule
