Verilog/VHDL codes for parallel to serial and vice versa
andy1
Full Member level 2
Full Member level 2
parallel to serial converter verilog
Could someone give me a sample code for paralle to serial AND serial to parallel conversion without any clock delay?
vhdl code for serial to parallel converter
What do you mean by "without any clock delay" ???
You can refer to following book .....in some chapter Serial to parallel is discussed.
Digital Design Principles and Practices by John F. Wakerly
vhdl code for parallel to serial converter
See The Attached Code
Serial_to_parallel Shift Register
Parallel_to_Serial Shift Register
can you help me with the same and give the code in verilog
it would be so grateful of you
