Luchete 1
Newbie
Hi, i'm learning about verilog and recently bought a max II CPLD kit, i was doing a verilog program trying to make a 7 segment display go form 0 to f on hex in a 1s delay (max II internal clk is 50MHz) between digits. i can't find the error in the syntaxis in that part of the code
Error (10170): Verilog HDL syntax error at Hex_7seg.v(3) near text: "reg"; expecting a direction.
module Hex_7seg(
input clk,
reg sig,
reg [6:0] seg_data,
output [6:0] seg
reg [25:0] contador;
reg [3:0] hex = 4'h0;
always @(posedge clk) begin
if (contador == 25000000)
begin
contador <= 0;
sig <= ~sig;
end
else begin
contador <= contador + 1;
end
end
//primer bloque me da en sig un clk de 1Hz
always @(negedge sig) begin
case (hex)
4'h0: seg_data = 7'b1000000; // 0
4'h1: seg_data = 7'b1111001; // 1
4'h2: seg_data = 7'b0100100; // 2
4'h3: seg_data = 7'b0110000; // 3
4'h4: seg_data = 7'b0011001; // 4
4'h5: seg_data = 7'b0010010; // 5
4'h6: seg_data = 7'b0000010; // 6
4'h7: seg_data = 7'b1111000; // 7
4'h8: seg_data = 7'b0000000; // 8
4'h9: seg_data = 7'b0011000; // 9
4'ha: seg_data = 7'b0001000; // A
4'hb: seg_data = 7'b0000011; // B
4'hc: seg_data = 7'b1000110; // C
4'hd: seg_data = 7'b0100001; // D
4'he: seg_data = 7'b0000110; // E
4'hf: seg_data = 7'b0001110; // F
default : seg_data = 7'b1110110; // U en caso de error
endcase
if (hex == 4'hf)
begin
hex <= 4'h0;
end
else
begin
hex <= hex +1;
end
end
seg <= seg_data;
endmodule
