Verilog, specify block
incisive
Member level 4
Member level 4
verilog specify
Where would u specify timing checks for a verilog simulator?
and interconnect delay?
verilog specify block
I beleive specify timing checks in the specify block itself,replacement is done using the back annotation i.e sdf file,
even i am not sure but hopeit is right
    incisive
specify in verilog
Hi incisive,
Your meaning specify the hierachical timing check in the Verilog simulator or select different ways to do timing check in simulator?
Please clear it.
specify block verilog
A specify block defines the timing section of the module in a separate block. As a result, the
functional verification becomes independent of the timing verification. The specify block can
remain unchanged at different levels of abstraction.
A specify block is bounded by the keywords specify and endspecify, and must appear within
a module definition.
Do not confuse specify parameters (keyword specparam, short for specify parameter) with
module parameters (keyword parameter). You declare module parameters outside a specify
block, and use them to configure instances of the module. You declare specparams inside a
specify block, and use them as timing constants.
This subsection describes specify block parameters, module path delays, pulse filtering
controls, and timing checks.
    incisive
