Verilog shift opearor question
bharath_kumar
Newbie level 2
Newbie level 2
HI all ,
reg [7:0] y0 ;  // reg
// r1 , g1 and b1 are 8 bit inputs.
assume r1 = 182 , g1 = 180 ; b1 = 183 ;
Case 1 : I used the code
yo <=  ( ( 7'd77*r0 )+( 8'd150*g0 )+( 5'd29*b0 ) ) >> 8	;
Case 2 : I used the code
y0  <= ( ( 7'd77*r0 )+( 8'd150*g0 )+( 5'd29*b0 ) ) / 256	;
In case (2) , i am getting the y0 180. ( this value is fine).
But in case (1) , i am getting 0 (zero) as out put.
I used the model SIM simulator.
Question : What is the problem with shift operator ???
Please answer me.
Best Regards
Bharath Kumar
Because the result requires 16-bits to fit before doing the >> operation.
Basically what is happening is the result of the multiplication and additions happens then the upper 8-bits are taken, except there aren't any upper 8-bits since y0a is only 8-bits. The / 256 does the division then assigns it so there is no need to keep track of the upper 8-bits.
1) use 16-bits for y0 and use only the upper 8-bits
2) use a 16-bit y0 and do the right shift and take only the lower 8-bits.
1 is the simplest to write.
Thanks ads ,
solution (1) , you mentioned is looking fine.
Best Regards
Bharath Kumar
