Verilog RAM initialization
riky126
Newbie level 1
Newbie level 1
Hi everybody, this is my first post in this forum and i need your help :)
I need to initialize different istances of the same verilog module RAM.v from a single data file for all instances (e.g. if i had 16 istances of RAM.v each with 10 WORD of 6 bit, then my data file consists of 10*16 lines of binary data).
I can't use readmemb because it addresses RAM to be initialized, not the data file.
I think i need something to choose read file start point and offset in order to initialize each RAM with different part of the data file. Is it possible?
P:S. Sorry for my bad english!
Two options I see:
For smaller RAMs, read the entire file into one big memory, then copy a slice of the memory into your RAMs. SystemVerilog makes this easy because you can copy slices of memories in a single assignment.
For larger memories, use $fscanf to read one word at a time, and store it in the appropriate memory.
