manili
Member level 1
Hi all,
I'm using Quartus II to compile a verilog code.
You can imaging the code as below :
File1.v:
reg A, B, C;
wire D, E, F;
task My_Task;
//use A, ..., F here.
endtask
File2.v:
module Top;
`include "File1.v"
//use My_Task here
endmodule
But the compiler does not compile my code and give me this error :
Error (error id): Verilog HDL error at File1.v(some line): declaring global objects is a SystemVerilog feature
Please correct me if I'm wrong:
The precompiler program should append File1.v into File2.v at the place that you write "`include "File1.v"". So there should be no problem with the code because it's just like to pass the following to the compiler :
File2.v:
module Top;
reg A, B, C;
wire D, E, F;
task My_Task;
endtask
//use My_Task here
endmodule
Thank you very much for your help.
File1.v:
reg A, B, C;
wire D, E, F;
task My_Task;
endtask
File2.v:
module Top;
`include "File1.v"
//use My_Task here
endmodule
File2.v:
module Top;
reg A, B, C;
wire D, E, F;
task My_Task;
endtask
//use My_Task here
endmodule
