Verilog code statement: #
Re: Verilog code statement
In a simulation enviroment - it'll assign d to q after 10 simulation ticks.
Or so I think...
Do mean by after 10 clock.
Code Verilog - [expand]
8
9
module dff8(q,d,clk);
   input [7:0]d;
    input clk;
    output  [7:0] q;
/*     always@(posedge clk)
    begin*/
assign q= #10 d;
   /* end*/
endmodule
What this module is doing?
It assings Q after 10 `timescale units.
For a `timescale of 1ns / 1ps, Q will be assigned after 10 ns.
1ps is the smallest time precision possible in the simulation.
What if the "clk" signal that triggers the always block is faster than 10 timescales ?
Will the assignment ever take effect?
The intra-assignment delay should also work with delay > schedule period. The RHS is evaluated immediately, the LHS assigned after the delay, creating a transport delay.
But there's no valid clock event in the above example.
Reactions: shaiko
    shaiko
As far as I understand - in VHDL one a process is entered (per sensitivity list) and a signal assignment is scheduled - any old scheduled assignments are overridden. This is UNLESS the "transport" keyword is used.
Are you saying that in Verilog all delays are transported by default?
The behavior isn't explicitly stated in the Verilog LRM, but I believe the intra-assignment delay syntax is the Verilog equivalent to VHDL transport delay.
Reactions: shaiko
    shaiko
