verilog code of an 8 bit FFT using block floating point arit
hirataqdees
Newbie level 5
Newbie level 5
pakistan
hey...
am new to verilog..and i have to implement an 8 bit FFT using block floating point arithmetic.i want to understand wht to do in it.
i need hep urgently..
regards
Re: verilog code of an 8 bit FFT using block floating point
The first step is to implement the floating point unit. Then, you use the butterfly structure to make the FFT.
For to start in floating point unit:
and FFT
https://en.wikipedia.org/wiki/Butterfly_diagram
thnx alot..
can u explain a bit what i have to do?
actually i have no idea what to do n how :( :(...
the first link u gave conains vhdl code while i need guidannce in verilog..
Added after 1 hours 19 minutes:
i have got idea abt tht sinconversion..now only prblem iz abt butterfly method..
Added after 2 minutes:
another thing is tht i need to implement tht thing for 8 bit...the sincomputer takes 20 inut data...
