verilog code for LFSR
rockgird
Junior Member level 3
lfsr verilog
hii,
i m writin a code for a 1-bit LFSR. but it isn't workin.
this is my code
module LFSR ( out ,clk );
input clk ;
wire clk ;
output out ;
wire out ;
reg Q1='b1;
wire Q2='b1, Q3='b1;
wire i='b0;
task dff;
output Q;
input D;
begin
assign Q = D;
end
endtask
always @(posedge clk)
begin
while(i<1)
begin
assign Q1=((Q2&(~Q3))|((~Q2)&Q3));
dff (Q2,Q1);
dff (Q3,Q2);
dff (Q1,Q3);
end;
end
endmodule
this is the error i m gettin
# Compile...
# Pass 1. Scanning modules hierarchy.
# Pass 2. Processing instantiations.
# Pass 3. Processing behavioral statements.
# Error: VCP2808 LFSR.v : (53, 14): Q OUTPUT/INOUT argument in dff task must be connected to a valid left-hand side of procedural assignment: Q2.
# Error: VCP2808 LFSR.v : (54, 14): Q OUTPUT/INOUT argument in dff task must be connected to a valid left-hand side of procedural assignment: Q3.
# Error: VCP2000 LFSR.v : (56, 5): Syntax error. Unexpected token: ;. Expected tokens: '#' , '(' , '{' , 'assign' , 'begin' ... .
# Compile failure 3 Errors 0 Warnings Analysis time : 1.
# done
block diagram is attached
ps:- I m usin Active HDL 6.3 for this person.
thanx in anticipation.
lfsr verilog code
You can try with the following code.
always @(posedge CLK or negedge RST_X) begin
if(!RST_X) begin
Q1_REG <= 'd0;
Q2_REG <= 'd0;
Q3_REG <= 'd0;
end
else begin
Q1_REG <= n_Q1_REG;
Q2_REG <= n_Q2_REG;
Q3_REG <= n_Q3_REG;
end
end
assign n_Q1_REG = Q2_REG ^ Q3_REG;
assign n_Q2_REG = Q1_REG;
assign n_Q3_REG = Q2_REG;
    rockgird
verilog lfsr
This will shifts the contents from MSB to LSB.
module lfsr #(parameter LFSR_WIDTH = 8,
TAP0 = 0,
TAP1 = 2,
TAP2 = 3,
TAP3 = 4)
(input clk,
input rst_n,
input din,
input load,
input shift,
output reg [LFSR_WIDTH-1:0] Q
reg [LFSR_WIDTH-1:0] Q_next;
always @(posedge clk or negedge rst_n)
begin
if(~rst_n)
Q <= {LFSR_WIDTH{1'b1}}; //Initialize LFSR to all ones
else
Q <= Q_next;
end
// XOR the taps
assign taps = Q[TAP0] ^ Q[TAP1] ^ Q[TAP2] ^ Q[TAP3];
//Calculate next state of the output
always @*
begin
Q_next = Q; // Default next state. (No shift)
if(load) //load din
Q_next = {din,Q[LFSR_WIDTH-1:1]};
else
if(shift) //shift the contents of Q with taps
Q_next = {taps,Q[LFSR_WIDTH-1:1]}; // Feedback is connected to FF[LFSR_WIDTH-1]
end
endmodule
