dirac16
Member level 5
I tried to simulate the following Verilog code by AMS simulator:
Here's the output for the input test signals shown ( i1 : IN1, i2 : IN2, clk : CLK, flg : FLG and sel : SELO)
The output registers SELO<1:0> and FLG just before the falling edge of CLK are 0 and 1, respectively. That is not what I expect because before a falling transition occurs on CLK, the statements inside the always block are not executed, so neither FLG nor SELO<1:0> should have certain values before CLK's falling transition (Rather they must be evaluated to x). What's wrong? It's like the always block is executed at time 0. I changed negedge to posedge and ran the same simulation with CLK changed to a rising edge type. This time the outputs were evaluated to x before CLK's rising transition. So not sure why the code does not work for negedge.
module test(i1,i2,clk,sel,flag);
input i1, i2;
input clk;
output reg [1:0] sel;
output reg flag;
always @(negedge clk) begin
sel[1] <= i1;
sel[0] <= i2;
flag <= 1;
end
endmodule
