As far as I can understand that the hardware required to implement the code below is not supported in Xilinx ISE Web Pack. I'm trying to implement only the functionality of the 8-bit adder using an always block. Here's the code:
module Addr_8bit(Clk, Rst, En, LEDOut
input Clk;
input Rst;
input En;
output reg [7:0] LEDOut;
always @(posedge Clk or posedge Rst) begin
if(Rst)
LEDOut <= 8'b00000000;
if(En)
LEDOut <= LEDOut + 8'b00000001;
end
endmodule
The error is on the line where the non-blocking assignment:
is located.
Particularly it says that:
ERROR:Xst:899 - "Addr_8bit.v" line 33: The logic for <LEDOut> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
I am trying to make the LEDOut's 8-bit output to correspond to the each single one of 8 LEDs on the BASYS2 FPGA Board(Spartan-3E).
Thank You.
