ShanghaiDSP
Newbie level 3
Hi to all,
I'm writing a generic multiplexer and facing a problem regarding Verilog.
I try to use a for-loop (with bounded index - to keep it synthesizable) and
assign a sliced part of the input to the output depending on cnt (one-hot encoded).
The idea is to slice a wide input vector (e.g. 128 bit) to a narrow (e.g. 32 bit) output
but in a generic way, so bit widths may change.
Consider the following code:
According Verilog 2001 spec the "+: " operator should be used,
because ":" is not sufficient when a index variable is involved.
But ModelSim 10.4 reports "Range width must be constant expression." for the "data_o = data_mux[((i+1)*LINK_WIDTH-1) +: (LINK_WIDTH*i)];" assignment
(verilog files are compiled as verilog 2001 version).
I checked several times...the width of sliced vector part is not changing during loop iterations.
For me this behavior is not understandable, starting from the introduction of indexed part-select "+:" operator. I can agree if someone tries to use a unbound for loop or the indexed bit width is changing. But verilog compiler just refuse in any case even if its a (in general) valid code.
Would be nice if someone could explain these limitation to me or where the error is :grin:
integer i;
always@(*) begin
data_o = data_mux[LINK_WIDTH-1 : 0];
for(i=0; i < SERDES_LEVEL ; i= i+1)
begin
if(cnt[i] == 1'b1)
begin
end
end
end
