Vehicle Tracking System Problem
Advanced Member level 6
Bangalore, India
I am doing a Vehicle Tracking System. My GPS works baudrate 4800 bps. I am using PIC18F46K22 at 20 MHz. I am just testing the receiving of GPS data. If I use ring buffer then it doesn't work. If I use just an ordinary buffer then I don'r get all the data. I am testing by echoing the data back to UART and watching the echo on PC. My GPS data frequency is 1 Hz. Please tell me how to receive GPS data properly and display it on PC?
If my ISR contains the below code it doesn't work but if I don't use ring buffer then it echos some part of the data.
Code C - [expand]
8
9
10
11
void Interrupt() {
          if(RC1IF_bit){
                 if(i > MAXBUFFSIZE)i = 0;
                 gpsData[i++] = RCREG1;
                 gpsData[i] = '\0';
Hope this will work. It's a Raspberry pi based code. But easy to port into MikroC .
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
 *  Description: This skecth gets the GPS coordinates and sends it
 *  through HTTP to a php script. For more information about the AT commands,
 *  refer to the AT command manual.
 *  Copyright (C) 2013 Libelium Comunicaciones Distribuidas S.L.
 *  [url]https://www.libelium.com[/url]
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see <http://www.gnu.org/licenses/>.
 *  Version 0.1
 *  Author: Alejandro Gallego
int8_t answer;
int onModulePin= 2;
char data[100];
int data_size;
char aux_str[30];
char aux;
int x = 0;
char N_S,W_E;
char url[] = "your ip address or your domain";
char frame[200];
char latitude[15];
char longitude[15];
char altitude[6];
char date[16];
char time[7];
char satellites[3];
char speedOTG[10];
char course[10];
void setup(){
    pinMode(onModulePin, OUTPUT);
    Serial.begin(115200);
    Serial.println("Starting...");
    power_on();
    delay(3000);
    // sets the PIN code
    sendATcommand("AT+CPIN=****", "OK", 2000);
    delay(3000);
    // starts the GPS and waits for signal
    while ( start_GPS() == 0);  //Not used
    // registration status on GSM NW
    while (sendATcommand("AT+CREG?", "+CREG: 0,1", 2000) == 0);
    // sets APN , user name and password
    sendATcommand("AT+SAPBR=3,1,\"Contype\",\"GPRS\"", "OK", 2000);
    sendATcommand("AT+SAPBR=3,1,\"APN\",\"apn\"", "OK", 2000);
    sendATcommand("AT+SAPBR=3,1,\"USER\",\"user_name\"", "OK", 2000);
    sendATcommand("AT+SAPBR=3,1,\"PWD\",\"password\"", "OK", 2000);
    // gets the GPRS bearer
    while (sendATcommand("AT+SAPBR=1,1", "OK", 20000) == 0)
        delay(5000);
void loop(){
    // gets GPS data
    get_GPS();
    // sends GPS data to the script
    send_HTTP();
    delay(5000);
void power_on(){
    uint8_t answer=0;
    // checks if the module is started
    answer = sendATcommand("AT", "OK", 2000);
    if (answer == 0)
        // power on pulse
        digitalWrite(onModulePin,HIGH);
        delay(3000);
        digitalWrite(onModulePin,LOW);
        // waits for an answer from the module
        while(answer == 0){
            // Send AT every two seconds and wait for the answer
int8_t start_GPS(){
    unsigned long previous;
    previous = millis();
    // starts the GPS
    sendATcommand("AT+CGPSPWR=1", "OK", 2000);
    sendATcommand("AT+CGPSRST=0", "OK", 2000);
    // waits for fix GPS
    while(( (sendATcommand("AT+CGPSSTATUS?", "2D Fix", 5000) ||
        sendATcommand("AT+CGPSSTATUS?", "3D Fix", 5000)) == 0 ) &&
        ((millis() - previous) < 90000));
    if ((millis() - previous) < 90000)
        return 1;
    else
        return 0;
int8_t get_GPS(){
    int8_t counter, answer;
    long previous;
    // First get the NMEA string
    // Clean the input buffer
    while( Serial.available() > 0) Serial.read();
    // request Basic string
    sendATcommand("AT+CGPSINF=0", "AT+CGPSINF=0\r\n\r\n", 2000);
    counter = 0;
    answer = 0;
    memset(frame, '\0', 100);    // Initialize the string
    // this loop waits for the NMEA string
    do{
        if(Serial.available() != 0){
            frame[counter] = Serial.read();
            counter++;
            // check if the desired answer is in the response of the module
            if (strstr(frame, "OK") != NULL)
                answer = 1;
        // Waits for the asnwer with time out
    while((answer == 0) && ((millis() - previous) < 2000));
    frame[counter-3] = '\0';
    // Parses the string
    strtok(frame, ",");
    strcpy(longitude,strtok(NULL, ",")); // Gets longitude
    strcpy(latitude,strtok(NULL, ",")); // Gets latitude
    strcpy(altitude,strtok(NULL, ".")); // Gets altitude
    strtok(NULL, ",");
    strcpy(date,strtok(NULL, ".")); // Gets date
    strtok(NULL, ",");
    strtok(NULL, ",");
    strcpy(satellites,strtok(NULL, ",")); // Gets satellites
    strcpy(speedOTG,strtok(NULL, ",")); // Gets speed over ground. Unit is knots.
    strcpy(course,strtok(NULL, "\r")); // Gets course
    convert2Degrees(latitude);
    convert2Degrees(longitude);
    return answer;
/* convert2Degrees ( input ) - performs the conversion from input
 * parameters in  DD°MM.mmm’ notation to DD.dddddd° notation.
 * Sign '+' is set for positive latitudes/longitudes (North, East)
 * Sign '-' is set for negative latitudes/longitudes (South, West)
int8_t convert2Degrees(char* input){
    float deg;
    float minutes;
    boolean neg = false;
    //auxiliar variable
    char aux[10];
    if (input[0] == '-')
        neg = true;
        strcpy(aux, strtok(input+1, "."));
    else
        strcpy(aux, strtok(input, "."));
    // convert string to integer and add it to final float variable
    deg = atof(aux);
    strcpy(aux, strtok(NULL, '\0'));
    minutes=atof(aux);
    minutes/=1000000;
    if (deg < 100)
        minutes += deg;
        deg = 0;
    else
        minutes += int(deg) % 100;
        deg = int(deg) / 100;
    // add minutes to degrees
    deg=deg+minutes/60;
    if (neg == true)
        deg*=-1.0;
    neg = false;
    if( deg < 0 ){
        neg = true;
        deg*=-1;
    float numeroFloat=deg;
    int parteEntera[10];
    int cifra;
    long numero=(long)numeroFloat;
    int size=0;
    while(1){
        size=size+1;
        cifra=numero%10;
        numero=numero/10;
        parteEntera[size-1]=cifra;
        if (numero==0){
            break;
    int indice=0;
    if( neg ){
        indice++;
        input[0]='-';
    for (int i=size-1; i >= 0; i--)
        input[indice]=parteEntera[i]+'0';
        indice++;
    input[indice]='.';
    indice++;
    numeroFloat=(numeroFloat-(int)numeroFloat);
    for (int i=1; i<=6 ; i++)
        numeroFloat=numeroFloat*10;
        cifra= (long)numeroFloat;
        numeroFloat=numeroFloat-cifra;
        input[indice]=char(cifra)+48;
        indice++;
    input[indice]='\0';
void send_HTTP(){
    // Initializes HTTP service
    answer = sendATcommand("AT+HTTPINIT", "OK", 10000);
    if (answer == 1)
        // Sets CID parameter
        answer = sendATcommand("AT+HTTPPARA=\"CID\",1", "OK", 5000);
        if (answer == 1)
            // Sets url
            sprintf(aux_str, "AT+HTTPPARA=\"URL\",\"http://%s/demo_sim908.php?", url);
            Serial.print(aux_str);
            sprintf(frame, "visor=false&latitude=%s&longitude=%s&altitude=%s&time=%s&satellites=%s&speedOTG=%s&course=%s",
            latitude, longitude, altitude, date, satellites, speedOTG, course);
            Serial.print(frame);
            answer = sendATcommand("\"", "OK", 5000);
            if (answer == 1)
                // Starts GET action
                answer = sendATcommand("AT+HTTPACTION=0", "+HTTPACTION:0,200", 30000);
                if (answer == 1)
                    Serial.println(F("Done!"));
                else
                    Serial.println(F("Error getting url"));
            else
                Serial.println(F("Error setting the url"));
        else
            Serial.println(F("Error setting the CID"));
    else
        Serial.println(F("Error initializating"));
    sendATcommand("AT+HTTPTERM", "OK", 5000);
int8_t sendATcommand(char* ATcommand, char* expected_answer1, unsigned int timeout){
    uint8_t x=0,  answer=0;
    char response[100];
    memset(response, '\0', 100);    // Initialize the string
    delay(100);
    while( Serial.available() > 0) Serial.read();    // Clean the input buffer
    Serial.println(ATcommand);    // Send the AT command
        x = 0;
    // this loop waits for the answer
    do{
            response[x] = Serial.read();
            x++;
            if (strstr(response, expected_answer1) != NULL)
                answer = 1;
    while((answer == 0) && ((millis() - previous) < timeout));
    return answer;
I am attaching my mikroC Code. There is a string gpsData2 for testing. If it is used in the while(1) loop then I get the parsed data on Serial Terminal. The problem I am facing is if I use gpsData for parsing I don't get anything on the Serial Terminal. What might be the problem. My GPS module give data at 1 Hz. So, I have 1 sec time between receiving gps data and echoing it back to UART. The echoing is not working. I am echoing just for testing to see that all the GPS data is received serially. Please give some advice.
  • VTS 13012013 rev1.rar
