leohart
Full Member level 4
Hi all,
1)Does normarlly mixed signal layout use two independent supplies?i.e.,vdda,gnda&vddd gndd,four pads on die and connect to four pins when packaging,then we connect vdda vddd and gndd gnda on pcb level.
2)If we can only use one pad for vdd and one pad for gnd on die,is it enough only to connect digital/analog gnd at one place and make its distance to gnd pad as short as possiable?I think this only prevents crosstalk at gnd,we should do the same thing for digital/analog vdd too,or otherwise,crosstalk will happen at vdd!
Any comment will be helpful!THX
