mazelk
VCO starting constrain
According with some reported VCO designs, active transconductance must overcome to tank transconductance, at least, in a factor of three (that they call "alpha" factor, or safety factor)
Why this amount?
I guess that it's not completelly true. As you increase "alpha", you increase transistor geometry (for same bias current) and drain capacitance (I mean about a complementary LC VCO). This reduce LC tank inyected current, and voltage swing. This increase phase noise.
Regarding those assumptions, which "safety factor " should I take to overcome tank loses?
Is it polite to consider that increasing "safety factor" could lead to drawback ??
Why this amount?
