VCO and CDR for a serializer/transceiver of 1 Gbit/s
mouzid
Full Member level 5
Full Member level 5
Hello,
For a serializer/Tranceiver of 1 Gbit/s using a pll of 1 Ghz, what should be the frequency of the clock driving the deserilizer/Receiver:
1 Ghz or 2 Ghz ?
VCO and CDR
I think that If the receiver / tranceiver are synchronous you should use 1 Ghz else you will need a CDR so a 2 Ghz clock.
    mouzid
VCO and CDR
It depends on the type of phase detector you are using. If you are using a full-rate phase detector , then you will need 1GHz clock. If you are using a half-rate PD then you only need a 0.5 GHz clock.
    mouzid
Re: VCO and CDR
Could ypu please Fahmy through more light on Full rate/ Hlaf rate PD ?
Thanks.
    mouzid
Re: VCO and CDR
Thanks.
Full-rate phase detectors are the conventional phase detectors (like Hogge PD and Alexander PD) these phase detectors operates on a clock with the same frequency of the incoming date (i.e clock frequency= bit rate). On the other hand, half-rate phase detectors are those phase detectors that operates by a VCO working at half the frequency of the incoming data (i.e. clock frequency = 1/2 * bit rate ). This feature is usually realized by taking more extra clocks from the VCO with multiple phases. attached some examples of half-rate PDs.
The main advantage of half-rate phase detectors is relaxing the speed and power contraints on most of the system by operating with a lower frequency.
Sorry for the late reply
