VB6 or C++ usb parallel port interface need help
shahrol_hisham
Full Member level 1
malaysia
c++ usb interface
Hi
I have a note book but it didnot have the parallel port so I used the usb to parallel port converter. But i dont kow how to controll this device using the VB and c++, can some one help me in how to write vb6 or c++ code interface the usb to parallel port converter.
PLS need help
virtual parallel port
Hi
I have search at the google, and most of the resource said we can used the "usbprint.sys" but I dont know how to interface with this file. can some one help me..
Thank
virtual parallel port driver
I don't think you can use usbprint.sys. This driver is used for driving USB printers, and that is not what you want. This web-site should be good place to start:
**broken link removed**.
vb6 usb to parallel
Assalamo Allykum !
On the ATEML site there are many drivers for the USB. Ithink you will find your required driver from there.
The site address is
www.atmel.com
Wish you a good Luck for this. :D :D
Take Care
Zeeshan Shareef
virtual parallel port usb
Check this out:
logix4u.net
coshkun said:
Check this out:
h**p://www.logix4u.net/parallelport1.htm
h**p://www.logix4u.net/inpout32.htm
hi
this site is about parallel port interfacing but is not about paralle to usb converters.
regards
virtual parallel port to usb
Normally if everything is installed fine you can program your parallel port like you do on a normal computer. (I used USB to serial convertor and I program my serial port just like normal COM port).
You have to figure out wich COM port is you port... and start programming.
Look in device manager. --> System --> Hardware configuration --> sort by connection --> see on USB bus what peripherals are connected. --> right mouse click on the convertor then properties will do the work....
kind regards
usb parallel programming vb
Hi
The usb to parallel port concerter not like the usb to serial converter, the usb to serial converter will create the virtual serial port but the usb parallel port not. I realy no idea how to solve this , pls help me..:cry:
c++ interface usb
i have this problem.
but now i try to write Device Driver for virtual parallel port.
usb vb6
Anybody has info about USB to parallel interface connectivity at USB side? it's needed to do any driver implementing a virtual port or an API interface.
TIA
virtual parallel port address
Do you kown usb interface?
vb6 usb
BuBEE
Can you teach me how to write virtual parallel port driver.
www.logix4u.net
kind regards
I don't understand.. can you give a little bit detail..TQ
virtual parallel usb
look pal
ANY parrallel port device usb or not
will create a handler in the address range of the device set in the device manager
if you look in usb devices part of the device manager applet
youll see there will be a driver for the port
open its properties youll see where you can address it
ie lpt1 lpt2 etc
you only need this device handle to be able to pass files to it using vb6
look at the proteus project #724566
in the bottom post of this topic
in the link youll find a parallel port project uses a ioportdll
you can com with the port and check it works
and his sources are there
so in the device manager applet usb device .. open its properties
in the advanced tab it should have a choose list for the port address
lpt1 lpt2 etc
lpt1 is always address 378h
look up the other detail
but its as pointed out as easy to address as a standard port
if your code requires a port id then it will simply be id0 as you only have one port
if it requires a device handle then it will be lpt1 etc... you never need to pass an address in c++ only the port id or handle
and the file and the port will respond
after all if it had no handler it wouldnt print either
c++ connect usb
I afraid it's not so easy to interface an usb connected parallel port since there isn't usually a driver to resemble a real LPT as it's the case which USB-serial ports and COM ports (virtual COM driver).
This issue is already discussed here:
Cheers ;-)
vb6 usbprint.sys
Hi BuBEE,
I'm also trying to develop the virtual parallel port driver connect to usb CDC. I have some idea, maybe we can talk!!^^
