sharikbaig
Member level 1
![Member level 1](/styles/images/ranks/dlevel1.gif)
A first chance exception of type 'System.OverflowException' occured in Microsoft.VisualBasic.dll
I am trying to read registers from PLC giving different values from 0 to 65536. However, at any instant, it shows this error and the value becomes 0. Please share your knowledge and tell me why is this happening and how to eliminate this error. Also sometimes i get StackOverflowException. Being a beginner in VB and a noob in programming, I have made this software with much efforts but this is what i got in the end. Any help would be appreciated.
Here's the FULL code:
' "404097" , "002071" etc are PLC's register numbers.
Thanks
Imports Communication
Imports Excel = Microsoft.Office.Interop.Excel
Public Class Form1
Dim plc As PLCEthernetReadWrite
Dim APP As New Excel.Application
Dim worksheet As Excel.Worksheet
Dim workbook As Excel.Workbook
Dim FilePath As String
Dim SpeedDisplay As Double
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
plc = New PLCEthernetReadWrite("192.168.1.5")
Timer1.Start()
FileVerificationLabel.Visible = False
Label3.Visible = True
Label4.Visible = True
S1m1.Visible = False
S2m1.Visible = False
S3m1.Visible = False
S4m1.Visible = False
S5m1.Visible = False
S6m1.Visible = False
S7m1.Visible = False
S8m1.Visible = False
S9m1.Visible = False
S10m1.Visible = False
S11m1.Visible = False
S12m1.Visible = False
S13m1.Visible = False
S14m1.Visible = False
S15m1.Visible = False
S16m1.Visible = False
S17m1.Visible = False
S18m1.Visible = False
S19m1.Visible = False
T1m1.Visible = False
T2m1.Visible = False
T3m1.Visible = False
T4m1.Visible = False
T5m1.Visible = False
T6m1.Visible = False
T7m1.Visible = False
T8m1.Visible = False
T9m1.Visible = False
T10m1.Visible = False
T11m1.Visible = False
T12m1.Visible = False
T13m1.Visible = False
T14m1.Visible = False
T15m1.Visible = False
T16m1.Visible = False
T17m1.Visible = False
T18m1.Visible = False
T19m1.Visible = False
End Sub
Private Sub Form1_FormClosed(ByVal sender As System.Object, ByVal e As System.Windows.Forms.FormClosedEventArgs) Handles MyBase.FormClosed
plc.writeword("404145", 0)
workbook.Application.DisplayAlerts = False
APP.Quit()
End Sub
Private Sub Timer1_Tick(sender As Object, e As EventArgs) Handles Timer1.Tick
MeterCount.Text = plc.ReadWord("404597")
MeterCount.Text = Val(MeterCount.Text) / 100
Label4.Text = plc.ReadWord("404141")
SpeedDisplay = Val(Label4.Text) / 1000
SpeedDisplay = Math.Round(SpeedDisplay, 1)
Speed.Text = SpeedDisplay
Label3.Text = plc.ReadWord("404145")
End Sub
Private Sub BrowseButton_Click(sender As Object, e As EventArgs) Handles BrowseButton.Click
Dim myFileDlog As New OpenFileDialog()
'look for files in the c drive
myFileDlog.InitialDirectory = "d:\Defects Data"
'specifies what type of data files to look for
myFileDlog.Filter = "All Files (*.xlsx*)|*.xlsx*"
'specifies which data type is focused on start up
myFileDlog.FilterIndex = 2
'Gets or sets a value indicating whether the dialog box restores the current directory before closing.
myFileDlog.RestoreDirectory = True
'seperates message outputs for files found or not found
If myFileDlog.ShowDialog() = _
DialogResult.OK Then
If Dir(myFileDlog.FileName) <> "" Then
MsgBox("File Loaded: " & _
myFileDlog.FileName, _
MsgBoxStyle.Information)
Else
MsgBox("File Not Found", _
MsgBoxStyle.Critical)
End If
End If
'Adds the file directory to the text box and Loads the File
PathTextBox.Text = myFileDlog.FileName
FilePath = Me.PathTextBox.Text
workbook = APP.Workbooks.Open(FilePath)
worksheet = workbook.Worksheets("sheet1")
PieceNoReadLabel.Text = worksheet.Cells(2, 1).Value
PieceMtrReadLabel.Text = worksheet.Cells(2, 3).Value
FileVerificationLabel.Text = worksheet.Cells(1, 1).Value
If FileVerificationLabel.Text <> "PieceNo" Then
MsgBox("Wrong File")
Else
MsgBox("Right File")
End If
'Defect Code Labels for data display:
DC1.Text = worksheet.Cells(2, 4).Value
DC2.Text = worksheet.Cells(3, 4).Value
DC3.Text = worksheet.Cells(4, 4).Value
DC4.Text = worksheet.Cells(5, 4).Value
DC5.Text = worksheet.Cells(6, 4).Value
DC6.Text = worksheet.Cells(7, 4).Value
DC7.Text = worksheet.Cells(8, 4).Value
DC8.Text = worksheet.Cells(9, 4).Value
DC9.Text = worksheet.Cells(10, 4).Value
DC10.Text = worksheet.Cells(11, 4).Value
DC11.Text = worksheet.Cells(12, 4).Value
DC12.Text = worksheet.Cells(13, 4).Value
DC13.Text = worksheet.Cells(14, 4).Value
DC14.Text = worksheet.Cells(15, 4).Value
DC15.Text = worksheet.Cells(16, 4).Value
DC16.Text = worksheet.Cells(17, 4).Value
DC17.Text = worksheet.Cells(18, 4).Value
DC18.Text = worksheet.Cells(19, 4).Value
DC19.Text = worksheet.Cells(20, 4).Value
'Defect Name Labels for data display:
DN1.Text = worksheet.Cells(2, 5).Value
DN2.Text = worksheet.Cells(3, 5).Value
DN3.Text = worksheet.Cells(4, 5).Value
DN4.Text = worksheet.Cells(5, 5).Value
DN5.Text = worksheet.Cells(6, 5).Value
DN6.Text = worksheet.Cells(7, 5).Value
DN7.Text = worksheet.Cells(8, 5).Value
DN8.Text = worksheet.Cells(9, 5).Value
DN9.Text = worksheet.Cells(10, 5).Value
DN10.Text = worksheet.Cells(11, 5).Value
DN11.Text = worksheet.Cells(12, 5).Value
DN12.Text = worksheet.Cells(13, 5).Value
DN13.Text = worksheet.Cells(14, 5).Value
DN14.Text = worksheet.Cells(15, 5).Value
DN15.Text = worksheet.Cells(16, 5).Value
DN16.Text = worksheet.Cells(17, 5).Value
DN17.Text = worksheet.Cells(18, 5).Value
DN18.Text = worksheet.Cells(19, 5).Value
DN19.Text = worksheet.Cells(20, 5).Value
'Start Meter Labels for data display:
S1.Text = worksheet.Cells(2, 6).Value
S2.Text = worksheet.Cells(3, 6).Value
S3.Text = worksheet.Cells(4, 6).Value
S4.Text = worksheet.Cells(5, 6).Value
S5.Text = worksheet.Cells(6, 6).Value
S6.Text = worksheet.Cells(7, 6).Value
S7.Text = worksheet.Cells(8, 6).Value
S8.Text = worksheet.Cells(9, 6).Value
S9.Text = worksheet.Cells(10, 6).Value
S10.Text = worksheet.Cells(11, 6).Value
S11.Text = worksheet.Cells(12, 6).Value
S12.Text = worksheet.Cells(13, 6).Value
S13.Text = worksheet.Cells(14, 6).Value
S14.Text = worksheet.Cells(15, 6).Value
S15.Text = worksheet.Cells(16, 6).Value
S16.Text = worksheet.Cells(17, 6).Value
S17.Text = worksheet.Cells(18, 6).Value
S18.Text = worksheet.Cells(19, 6).Value
S19.Text = worksheet.Cells(20, 6).Value
'End Meter Labels for data display:
T1.Text = worksheet.Cells(2, 7).Value
T2.Text = worksheet.Cells(3, 7).Value
T3.Text = worksheet.Cells(4, 7).Value
T4.Text = worksheet.Cells(5, 7).Value
T5.Text = worksheet.Cells(6, 7).Value
T6.Text = worksheet.Cells(7, 7).Value
T7.Text = worksheet.Cells(8, 7).Value
T8.Text = worksheet.Cells(9, 7).Value
T9.Text = worksheet.Cells(10, 7).Value
T10.Text = worksheet.Cells(11, 7).Value
T11.Text = worksheet.Cells(12, 7).Value
T12.Text = worksheet.Cells(13, 7).Value
T13.Text = worksheet.Cells(14, 7).Value
T14.Text = worksheet.Cells(15, 7).Value
T15.Text = worksheet.Cells(16, 7).Value
T16.Text = worksheet.Cells(17, 7).Value
T17.Text = worksheet.Cells(18, 7).Value
T18.Text = worksheet.Cells(19, 7).Value
T19.Text = worksheet.Cells(20, 7).Value
'Do not display 0 for Start Meter & 'Minus 1 for PLC
If S1.Text = "0" Then
S1.Visible = False
S1m1.Text = S1.Text
Else
S1.Visible = True
S1m1.Text = Val(S1.Text) - 1
End If
If S2.Text = "0" Then
S2.Visible = False
S2m1.Text = S2.Text
Else
S2.Visible = True
S2m1.Text = Val(S2.Text) - 1
End If
If S3.Text = "0" Then
S3.Visible = False
S3m1.Text = S3.Text
Else
S3.Visible = True
S3m1.Text = Val(S3.Text) - 1
End If
If S4.Text = "0" Then
S4.Visible = False
S4m1.Text = S4.Text
Else
S4.Visible = True
S4m1.Text = Val(S4.Text) - 1
End If
If S5.Text = "0" Then
S5.Visible = False
S5m1.Text = S5.Text
Else
S5.Visible = True
S5m1.Text = Val(S5.Text) - 1
End If
If S6.Text = "0" Then
S6.Visible = False
S6m1.Text = S6.Text
Else
S6.Visible = True
S6m1.Text = Val(S6.Text) - 1
End If
If S7.Text = "0" Then
S7.Visible = False
S7m1.Text = S7.Text
Else
S7.Visible = True
S7m1.Text = Val(S7.Text) - 1
End If
If S8.Text = "0" Then
S8.Visible = False
S8m1.Text = S8.Text
Else
S8.Visible = True
S8m1.Text = Val(S8.Text) - 1
End If
If S9.Text = "0" Then
S9.Visible = False
S9m1.Text = S9.Text
Else
S9.Visible = True
S9m1.Text = Val(S9.Text) - 1
End If
If S10.Text = "0" Then
S10.Visible = False
S10m1.Text = S10.Text
Else
S10.Visible = True
S10m1.Text = Val(S10.Text) - 1
End If
If S11.Text = "0" Then
S11.Visible = False
S11m1.Text = S11.Text
Else
S11.Visible = True
S11m1.Text = Val(S11.Text) - 1
End If
If S12.Text = "0" Then
S12.Visible = False
S12m1.Text = S12.Text
Else
S12.Visible = True
S12m1.Text = Val(S12.Text) - 1
End If
If S13.Text = "0" Then
S13.Visible = False
S13m1.Text = S13.Text
Else
S13.Visible = True
S13m1.Text = Val(S13.Text) - 1
End If
If S14.Text = "0" Then
S14.Visible = False
S14m1.Text = S14.Text
Else
S14.Visible = True
S14m1.Text = Val(S14.Text) - 1
End If
If S15.Text = "0" Then
S15.Visible = False
S15m1.Text = S15.Text
Else
S15.Visible = True
S15m1.Text = Val(S15.Text) - 1
End If
If S16.Text = "0" Then
S16.Visible = False
S16m1.Text = S16.Text
Else
S16.Visible = True
S16m1.Text = Val(S16.Text) - 1
End If
If S17.Text = "0" Then
S17.Visible = False
S17m1.Text = S17.Text
Else
S17.Visible = True
S17m1.Text = Val(S17.Text) - 1
End If
If S18.Text = "0" Then
S18.Visible = False
S18m1.Text = S18.Text
Else
S18.Visible = True
S18m1.Text = Val(S18.Text) - 1
End If
If S19.Text = "0" Then
S19.Visible = False
S19m1.Text = S19.Text
Else
S19.Visible = True
S19m1.Text = Val(S19.Text) - 1
End If
'Do not display 0 for End Meter
If T1.Text = "0" Then
T1.Visible = False
T1m1.Text = T1.Text
Else
T1.Visible = True
T1m1.Text = Val(T1.Text) - 1
End If
If T2.Text = "0" Then
T2.Visible = False
T2m1.Text = T2.Text
Else
T2.Visible = True
T2m1.Text = Val(T2.Text) - 1
End If
If T3.Text = "0" Then
T3.Visible = False
T3m1.Text = T3.Text
Else
T3.Visible = True
T3m1.Text = Val(T3.Text) - 1
End If
If T4.Text = "0" Then
T4.Visible = False
T4m1.Text = T4.Text
Else
T4.Visible = True
T4m1.Text = Val(T4.Text) - 1
End If
If T5.Text = "0" Then
T5.Visible = False
T5m1.Text = T5.Text
Else
T5.Visible = True
T5m1.Text = Val(T5.Text) - 1
End If
If T6.Text = "0" Then
T6.Visible = False
T6m1.Text = T6.Text
Else
T6.Visible = True
T6m1.Text = Val(T6.Text) - 1
End If
If T7.Text = "0" Then
T7.Visible = False
T7m1.Text = T7.Text
Else
T7.Visible = True
T7m1.Text = Val(T7.Text) - 1
End If
If T8.Text = "0" Then
T8.Visible = False
T8m1.Text = T8.Text
Else
T8.Visible = True
T8m1.Text = Val(T8.Text) - 1
End If
If T9.Text = "0" Then
T9.Visible = False
T9m1.Text = T9.Text
Else
T9.Visible = True
T9m1.Text = Val(T9.Text) - 1
End If
If T10.Text = "0" Then
T10.Visible = False
T10m1.Text = T10.Text
Else
T10.Visible = True
T10m1.Text = Val(T10.Text) - 1
End If
If T11.Text = "0" Then
T11.Visible = False
T11m1.Text = T11.Text
Else
T11.Visible = True
T11m1.Text = Val(T11.Text) - 1
End If
If T12.Text = "0" Then
T12.Visible = False
T12m1.Text = T12.Text
Else
T12.Visible = True
T12m1.Text = Val(T12.Text) - 1
End If
If T13.Text = "0" Then
T13.Visible = False
T13m1.Text = T13.Text
Else
T13.Visible = True
T13m1.Text = Val(T13.Text) - 1
End If
If T14.Text = "0" Then
T14.Visible = False
T14m1.Text = T14.Text
Else
T14.Visible = True
T14m1.Text = Val(T14.Text) - 1
End If
If T15.Text = "0" Then
T15.Visible = False
T15m1.Text = T15.Text
Else
T15.Visible = True
T15m1.Text = Val(T15.Text) - 1
End If
If T16.Text = "0" Then
T16.Visible = False
T16m1.Text = T16.Text
Else
T16.Visible = True
T16m1.Text = Val(T16.Text) - 1
End If
If T17.Text = "0" Then
T17.Visible = False
T17m1.Text = T17.Text
Else
T17.Visible = True
T17m1.Text = Val(T17.Text) - 1
End If
If T18.Text = "0" Then
T18.Visible = False
T18m1.Text = T18.Text
Else
T18.Visible = True
T18m1.Text = Val(T18.Text) - 1
End If
If T19.Text = "0" Then
T19.Visible = False
T19m1.Text = T19.Text
Else
T19.Visible = True
T19m1.Text = Val(T19.Text) - 1
End If
'Writing to PLC
plc.writeword("404518", S1m1.Text)
plc.writeword("404519", T1m1.Text)
plc.writeword("404520", S2m1.Text)
plc.writeword("404521", T2m1.Text)
plc.writeword("404522", S3m1.Text)
plc.writeword("404523", T3m1.Text)
plc.writeword("404524", S4m1.Text)
plc.writeword("404525", T4m1.Text)
plc.writeword("404526", S5m1.Text)
plc.writeword("404527", T5m1.Text)
plc.writeword("404528", S6m1.Text)
plc.writeword("404529", T6m1.Text)
plc.writeword("404530", S7m1.Text)
plc.writeword("404531", T7m1.Text)
plc.writeword("404532", S8m1.Text)
plc.writeword("404533", T8m1.Text)
plc.writeword("404534", S9m1.Text)
plc.writeword("404535", T9m1.Text)
plc.writeword("404536", S10m1.Text)
plc.writeword("404537", T10m1.Text)
plc.writeword("404538", S11m1.Text)
plc.writeword("404539", T11m1.Text)
plc.writeword("404540", S12m1.Text)
plc.writeword("404541", T12m1.Text)
plc.writeword("404542", S13m1.Text)
plc.writeword("404543", T13m1.Text)
plc.writeword("404544", S14m1.Text)
plc.writeword("404545", T14m1.Text)
plc.writeword("404546", S15m1.Text)
plc.writeword("404547", T15m1.Text)
plc.writeword("404548", S16m1.Text)
plc.writeword("404549", T16m1.Text)
plc.writeword("404550", S17m1.Text)
plc.writeword("404551", T17m1.Text)
plc.writeword("404552", S18m1.Text)
plc.writeword("404553", T18m1.Text)
plc.writeword("404554", S19m1.Text)
plc.writeword("404555", T19m1.Text)
plc.writeword("404505", PieceMtrReadLabel.Text)
End Sub
Private Sub Timer2_Tick(sender As Object, e As EventArgs) Handles Timer2.Tick
If Val(MeterCount.Text) >= Val(S1.Text) And Val(MeterCount.Text) <= Val(T1.Text) Then
DC1.BackColor = Color.Orange
DN1.BackColor = Color.Orange
S1.BackColor = Color.Orange
T1.BackColor = Color.Orange
worksheet.Cells(2, 9).Value = "Incomplete"
Else
DC1.BackColor = Color.Transparent
DN1.BackColor = Color.Transparent
S1.BackColor = Color.Transparent
T1.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T1.Text) Then
DC1.BackColor = Color.LightGreen
DN1.BackColor = Color.LightGreen
S1.BackColor = Color.LightGreen
T1.BackColor = Color.LightGreen
worksheet.Cells(2, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S2.Text) And Val(MeterCount.Text) <= Val(T2.Text) Then
DC2.BackColor = Color.Orange
DN2.BackColor = Color.Orange
S2.BackColor = Color.Orange
T2.BackColor = Color.Orange
worksheet.Cells(3, 9).Value = "Incomplete"
Else
DC2.BackColor = Color.Transparent
DN2.BackColor = Color.Transparent
S2.BackColor = Color.Transparent
T2.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T2.Text) Then
DC2.BackColor = Color.LightGreen
DN2.BackColor = Color.LightGreen
S2.BackColor = Color.LightGreen
T2.BackColor = Color.LightGreen
worksheet.Cells(3, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S3.Text) And Val(MeterCount.Text) <= Val(T3.Text) Then
DC3.BackColor = Color.Orange
DN3.BackColor = Color.Orange
S3.BackColor = Color.Orange
T3.BackColor = Color.Orange
worksheet.Cells(4, 9).Value = "Incomplete"
Else
DC3.BackColor = Color.Transparent
DN3.BackColor = Color.Transparent
S3.BackColor = Color.Transparent
T3.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T3.Text) Then
DC3.BackColor = Color.LightGreen
DN3.BackColor = Color.LightGreen
S3.BackColor = Color.LightGreen
T3.BackColor = Color.LightGreen
worksheet.Cells(4, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S4.Text) And Val(MeterCount.Text) <= Val(T4.Text) Then
DC4.BackColor = Color.Orange
DN4.BackColor = Color.Orange
S4.BackColor = Color.Orange
T4.BackColor = Color.Orange
worksheet.Cells(5, 9).Value = "Incomplete"
Else
DC4.BackColor = Color.Transparent
DN4.BackColor = Color.Transparent
S4.BackColor = Color.Transparent
T4.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T4.Text) Then
DC4.BackColor = Color.LightGreen
DN4.BackColor = Color.LightGreen
S4.BackColor = Color.LightGreen
T4.BackColor = Color.LightGreen
worksheet.Cells(5, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S5.Text) And Val(MeterCount.Text) <= Val(T5.Text) Then
DC5.BackColor = Color.Orange
DN5.BackColor = Color.Orange
S5.BackColor = Color.Orange
T5.BackColor = Color.Orange
worksheet.Cells(6, 9).Value = "Incomplete"
Else
DC5.BackColor = Color.Transparent
DN5.BackColor = Color.Transparent
S5.BackColor = Color.Transparent
T5.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T5.Text) Then
DC5.BackColor = Color.LightGreen
DN5.BackColor = Color.LightGreen
S5.BackColor = Color.LightGreen
T5.BackColor = Color.LightGreen
worksheet.Cells(6, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S6.Text) And Val(MeterCount.Text) <= Val(T6.Text) Then
DC6.BackColor = Color.Orange
DN6.BackColor = Color.Orange
S6.BackColor = Color.Orange
T6.BackColor = Color.Orange
worksheet.Cells(7, 9).Value = "Incomplete"
Else
DC6.BackColor = Color.Transparent
DN6.BackColor = Color.Transparent
S6.BackColor = Color.Transparent
T6.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T6.Text) Then
DC6.BackColor = Color.LightGreen
DN6.BackColor = Color.LightGreen
S6.BackColor = Color.LightGreen
T6.BackColor = Color.LightGreen
worksheet.Cells(7, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S7.Text) And Val(MeterCount.Text) <= Val(T7.Text) Then
DC7.BackColor = Color.Orange
DN7.BackColor = Color.Orange
S7.BackColor = Color.Orange
T7.BackColor = Color.Orange
worksheet.Cells(8, 9).Value = "Incomplete"
Else
DC7.BackColor = Color.Transparent
DN7.BackColor = Color.Transparent
S7.BackColor = Color.Transparent
T7.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T7.Text) Then
DC7.BackColor = Color.LightGreen
DN7.BackColor = Color.LightGreen
S7.BackColor = Color.LightGreen
T7.BackColor = Color.LightGreen
worksheet.Cells(8, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S8.Text) And Val(MeterCount.Text) <= Val(T8.Text) Then
DC8.BackColor = Color.Orange
DN8.BackColor = Color.Orange
S8.BackColor = Color.Orange
T8.BackColor = Color.Orange
worksheet.Cells(9, 9).Value = "Incomplete"
Else
DC8.BackColor = Color.Transparent
DN8.BackColor = Color.Transparent
S8.BackColor = Color.Transparent
T8.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T8.Text) Then
DC8.BackColor = Color.LightGreen
DN8.BackColor = Color.LightGreen
S8.BackColor = Color.LightGreen
T8.BackColor = Color.LightGreen
worksheet.Cells(9, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S9.Text) And Val(MeterCount.Text) <= Val(T9.Text) Then
DC9.BackColor = Color.Orange
DN9.BackColor = Color.Orange
S9.BackColor = Color.Orange
T9.BackColor = Color.Orange
worksheet.Cells(10, 9).Value = "Incomplete"
Else
DC9.BackColor = Color.Transparent
DN9.BackColor = Color.Transparent
S9.BackColor = Color.Transparent
T9.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T9.Text) Then
DC9.BackColor = Color.LightGreen
DN9.BackColor = Color.LightGreen
S9.BackColor = Color.LightGreen
T9.BackColor = Color.LightGreen
worksheet.Cells(10, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S10.Text) And Val(MeterCount.Text) <= Val(T10.Text) Then
DC10.BackColor = Color.Orange
DN10.BackColor = Color.Orange
S10.BackColor = Color.Orange
T10.BackColor = Color.Orange
worksheet.Cells(11, 9).Value = "Incomplete"
Else
DC10.BackColor = Color.Transparent
DN10.BackColor = Color.Transparent
S10.BackColor = Color.Transparent
T10.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T10.Text) Then
DC10.BackColor = Color.LightGreen
DN10.BackColor = Color.LightGreen
S10.BackColor = Color.LightGreen
T10.BackColor = Color.LightGreen
worksheet.Cells(11, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S11.Text) And Val(MeterCount.Text) <= Val(T11.Text) Then
DC11.BackColor = Color.Orange
DN11.BackColor = Color.Orange
S11.BackColor = Color.Orange
T11.BackColor = Color.Orange
worksheet.Cells(12, 9).Value = "Incomplete"
Else
DC11.BackColor = Color.Transparent
DN11.BackColor = Color.Transparent
S11.BackColor = Color.Transparent
T11.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T11.Text) Then
DC11.BackColor = Color.LightGreen
DN11.BackColor = Color.LightGreen
S11.BackColor = Color.LightGreen
T11.BackColor = Color.LightGreen
worksheet.Cells(12, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S12.Text) And Val(MeterCount.Text) <= Val(T12.Text) Then
DC12.BackColor = Color.Orange
DN12.BackColor = Color.Orange
S12.BackColor = Color.Orange
T12.BackColor = Color.Orange
worksheet.Cells(13, 9).Value = "Incomplete"
Else
DC12.BackColor = Color.Transparent
DN12.BackColor = Color.Transparent
S12.BackColor = Color.Transparent
T12.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T12.Text) Then
DC12.BackColor = Color.LightGreen
DN12.BackColor = Color.LightGreen
S12.BackColor = Color.LightGreen
T12.BackColor = Color.LightGreen
worksheet.Cells(13, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S13.Text) And Val(MeterCount.Text) <= Val(T13.Text) Then
DC13.BackColor = Color.Orange
DN13.BackColor = Color.Orange
S13.BackColor = Color.Orange
T13.BackColor = Color.Orange
worksheet.Cells(14, 9).Value = "Incomplete"
Else
DC13.BackColor = Color.Transparent
DN13.BackColor = Color.Transparent
S13.BackColor = Color.Transparent
T13.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T13.Text) Then
DC13.BackColor = Color.LightGreen
DN13.BackColor = Color.LightGreen
S13.BackColor = Color.LightGreen
T13.BackColor = Color.LightGreen
worksheet.Cells(14, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S14.Text) And Val(MeterCount.Text) <= Val(T14.Text) Then
DC14.BackColor = Color.Orange
DN14.BackColor = Color.Orange
S14.BackColor = Color.Orange
T14.BackColor = Color.Orange
worksheet.Cells(15, 9).Value = "Incomplete"
Else
DC14.BackColor = Color.Transparent
DN14.BackColor = Color.Transparent
S14.BackColor = Color.Transparent
T14.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T14.Text) Then
DC14.BackColor = Color.LightGreen
DN14.BackColor = Color.LightGreen
S14.BackColor = Color.LightGreen
T14.BackColor = Color.LightGreen
worksheet.Cells(15, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S15.Text) And Val(MeterCount.Text) <= Val(T15.Text) Then
DC15.BackColor = Color.Orange
DN15.BackColor = Color.Orange
S15.BackColor = Color.Orange
T15.BackColor = Color.Orange
worksheet.Cells(16, 9).Value = "Incomplete"
Else
DC15.BackColor = Color.Transparent
DN15.BackColor = Color.Transparent
S15.BackColor = Color.Transparent
T15.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T15.Text) Then
DC15.BackColor = Color.LightGreen
DN15.BackColor = Color.LightGreen
S15.BackColor = Color.LightGreen
T15.BackColor = Color.LightGreen
worksheet.Cells(16, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S16.Text) And Val(MeterCount.Text) <= Val(T16.Text) Then
DC16.BackColor = Color.Orange
DN16.BackColor = Color.Orange
S16.BackColor = Color.Orange
T16.BackColor = Color.Orange
worksheet.Cells(17, 9).Value = "Incomplete"
Else
DC16.BackColor = Color.Transparent
DN16.BackColor = Color.Transparent
S16.BackColor = Color.Transparent
T16.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T16.Text) Then
DC16.BackColor = Color.LightGreen
DN16.BackColor = Color.LightGreen
S16.BackColor = Color.LightGreen
T16.BackColor = Color.LightGreen
worksheet.Cells(17, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S17.Text) And Val(MeterCount.Text) <= Val(T17.Text) Then
DC17.BackColor = Color.Orange
DN17.BackColor = Color.Orange
S17.BackColor = Color.Orange
T17.BackColor = Color.Orange
worksheet.Cells(18, 9).Value = "Incomplete"
Else
DC17.BackColor = Color.Transparent
DN17.BackColor = Color.Transparent
S17.BackColor = Color.Transparent
T17.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T17.Text) Then
DC17.BackColor = Color.LightGreen
DN17.BackColor = Color.LightGreen
S17.BackColor = Color.LightGreen
T17.BackColor = Color.LightGreen
worksheet.Cells(18, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S18.Text) And Val(MeterCount.Text) <= Val(T18.Text) Then
DC18.BackColor = Color.Orange
DN18.BackColor = Color.Orange
S18.BackColor = Color.Orange
T18.BackColor = Color.Orange
worksheet.Cells(19, 9).Value = "Incomplete"
Else
DC18.BackColor = Color.Transparent
DN18.BackColor = Color.Transparent
S18.BackColor = Color.Transparent
T18.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T18.Text) Then
DC18.BackColor = Color.LightGreen
DN18.BackColor = Color.LightGreen
S18.BackColor = Color.LightGreen
T18.BackColor = Color.LightGreen
worksheet.Cells(19, 9).Value = "Processed"
End If
If Val(MeterCount.Text) >= Val(S19.Text) And Val(MeterCount.Text) <= Val(T19.Text) Then
DC19.BackColor = Color.Orange
DN19.BackColor = Color.Orange
S19.BackColor = Color.Orange
T19.BackColor = Color.Orange
worksheet.Cells(20, 9).Value = "Incomplete"
Else
DC19.BackColor = Color.Transparent
DN19.BackColor = Color.Transparent
S19.BackColor = Color.Transparent
T19.BackColor = Color.Transparent
End If
If Val(MeterCount.Text) >= Val(T19.Text) Then
DC19.BackColor = Color.LightGreen
DN19.BackColor = Color.LightGreen
S19.BackColor = Color.LightGreen
T19.BackColor = Color.LightGreen
worksheet.Cells(20, 9).Value = "Processed"
End If
End Sub
Private Sub StartButton_Click(sender As Object, e As EventArgs) Handles StartButton.Click
plc.writeword("404217", 1)
Threading.Thread.Sleep(1000)
plc.writeword("404217", 0)
StartButton.Enabled = False
BrowseButton.Enabled = False
PathTextBox.Enabled = False
PathLabel.Enabled = False
End Sub
End Class
Thanks
