VB : how to catch a nag screen msgbox at first dll call ?
tgq
Full Member level 5
Full Member level 5
dll nagscreen
Hi
I use NT port library 2.0 unregistred, fully functionnal but with a nag screen at the first dll call
How to catch/escape this nag screen with VB ?
Is there a better idea (API ?) than call a useless read port at form load and send an "enter" key ?
kill nag screen in vb
It is not necessary to send enter key to program.Just patch it. If you are experienced to patch executables have a look at :
hxxp://www.protools.cjb.net/
Cheers,
Analyzer.
howto nag screen
you will need some API-calls
to get the handle of the window you want to close:
Declare Function EnumWindows Lib "user32" (ByVal lpEnumFunc As Long, ByVal lParam As Long) As Long
Declare Function GetWindowText Lib "user32" Alias "GetWindowTextA" (ByVal hwnd As Long, ByVal lpString As String, ByVal cch As Long) As Long
to close it:
Declare Function SendMessageTimeout Lib "user32" Alias "SendMessageTimeoutA" (ByVal hwnd As Long, ByVal msg As Long, ByVal wParam As Long, ByVal lParam As Long, ByVal fuFlags As Long, ByVal uTimeout As Long, lpdwResult As Long) As Long
declare function enumwindows -callback -addressof
Hi
You must do some reverse staff on it and catch "messageboxa" API and with a HEX editor kill the calling procedure.
Trust me it is so easy work.
