stoyanoff
Full Member level 4
Greatings! I`m using an etalon resistor for measuring current in high voltage circuit. I`m using 0.01 ohm resistor and OA(the attached file). There is a chance the voltage drop on the resistor to reise dramaticly in malfunction of the device. So I want to put somekind of protection. I want to be sure in case of malfunction my chart will stay untouched.
So I want to use varistor. I`m not sure if I must just put a varistor in paralel with the resistor. I found in shops varistor 10К. I don`t know do i have to calculate the value of this varistor or just to put one at the entrance???
Is it a good idea to use a cener diode???
