varistor for 230v supply
Hello,
basically your supply lines apparently conduct transients of higher energy than your varistor could absorb without damage. You either should use a "stronger" type (bigger in size) or a higher voltage type, if transient voltage isn't very high and the protection purpose would be still served. Regarding the capacitor, you should be able to find a higher voltage type that could be fully protected by the varistor. I wonder if 100 pF has an effect at all, if the value is printed correct.
You should also be aware that some voltage transients, e. g. from direct and indirect lightling effects could be hardly handled by small varistors. At best they protect the downstream devices by shortening the overvoltage irreversibly.
Regards,
Frank
