variable voltage output using pwm
vijay b@dboy
Newbie level 2
Newbie level 2
i want to generate variable voltage output according to pwm's dutycycle.so which ic or circuit is preferable??please suggest as soon as possible.
To convert a PWM output to an analog voltage use a low-pass filter.
According to your PWM frequency For example 9.76Khz you can have an R = 4.7K and C = 1.0uF. This gives a bandwidth of 30Hz.
https://www.ontrak.net/pwm.htm
