johnwnixon
Newbie level 2
site:www.edaboard.com in5404
I have what should hopefully be a simple question. Please forgive my ignorance, my knowledge in this arena is limited.
I have a trigger from a variable speed powered screw driver that I want to replace with a knob that will control the speed of the motor. The screwdriver is 12VDC. The trigger has a rectifier (IN5404) and a transistor? which is labelled:
P75NF 75 @
75 AFV V6
PHL 625
The transistor is glued to a heat sink.
I would like help with two things -
1.) Locating the correct sized potentiometer (or do I need a rheostat?).
2.) How to wire the new pot with the existing components I have to make an effective variable speed control.
Thanks for any help you can provide this novice!
John Nixon
P75NF 75 @
75 AFV V6
PHL 625
John Nixon
