Variable load with stepless current draw
manishanand14
Full Member level 4
Full Member level 4
Bangalore ,India
Hello Everyone!
I want to make a continuously variable load[resistive] which should draw current in the range 100mA-2A.
Voltage across the load 3-12V.
This means you need a 25 watt load. (12V @ 2A). A 25 watt, 125 ohm rheostat that would do the job.
Are there more requirements?
Instead can I not use a suitable rating transistor in active mode.
The base current will decide the collector current which will flow through a resistive load.(Say a wire wound resistor of suitable wattage).
The unpleasant point is to require both 120 ohm and 2 A, which refers to a 480 W rheostat, unfortunately.
Yes, the power rating (heatsink size) has to be selected according to the intended V and A combination.
