convoluted
Newbie level 2
Hey all,
I'm planning on building a 1.2-18V @ 1.5A variable DC power supply using an LM317 variable regulator. The circuit I plan on following is seen here: **broken link removed**. I will be using a 19V @ 6A AC laptop adapter (VERY cheap on eBay, couldn't resist) and I would like to double the circuit such that I have two 1.5A channels to work with. My question is, would I be able to replicate the circuit and draw from the same power supply without issue, or would the two circuits interfere with on another somehow? Obviously the ground will be common between the two circuits, as would be the power supply. Is there anything I need to consider, noise issues, power requirements, etc?
Thanks in advance
Thanks in advance
