Nbrooks
Newbie level 1
So here is what I am trying to accomplish. I am trying to take an old Jacobs wind turbine controller that was designed for a grid tie application and make it off grid. There is a 3 phase "wild" ac input from the turbine that is rectifyed but not clipped by the internal SCR's to variable DC (40-180 volts). The sensing was designed to tie to the grid and power sync'd to line power and freq then exported or imported depending on demand.
What I would like to do is build a Variable Dc input inverter that will put out a pure sine wave 120/240 vac split phase. Thus imprinting a usable power out put and allowing the cap/choke inverter to do its part. The design need not handle much power as it is only used as an imprint to regulate the power through the controller.
If anyone had any idea on a build for this or a manufacturer that is producing such an item I could really use some ideas.
Thanks
Thanks
